Old 04-14-2009, 08:47 PM   #1
jb1016
"Oh well, it's a driver."
jb1016's Avatar
why does my truck sit level?
First off, I apologize, cuz I'm a freakin' noob when it comes to suspension stuff. I've got a 93 shorty, and it sits level -- 32" front, 32" rear. I like that it's level, but I want to go a little lower in the future, and all the mild kits out there are designed for a bigger drop in the rear. I'm hoping somebody can tell me why it's lower than stock in back? There's nothing back there that looks aftermarket...do the leaf springs sag over time? Is it possible that one of the leaves was taken out of each side? Or could it just be that my shocks are worn out?
Thx in advance, and sorry for the noobie questions
Old 04-14-2009, 11:50 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: why does my truck sit level?
Most 88-98's sit high in the rear. Just adding a shackle makes a big difference in appearance.
While it could be leaves that have sagged, I would look closely at your rear suspension. Are you sure the shackles are stock? Does it have the lower overload spring in place?
Something doesn't sound normal to me.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-15-2009, 01:05 AM   #3
the lights
the lights's Avatar
correct me if i am wrong but dont these trucks have a type of torsion bar system that will raise or lower the front? could be why it is level.
the lights is offline   Reply With Quote
Old 04-15-2009, 07:35 AM   #4
nicks05z71
nicks05z71's Avatar
4x4s in that year have torsion fronts. 2wd would have coils.
nicks05z71 is offline   Reply With Quote
Old 04-15-2009, 12:22 PM   #5
jb1016
jb1016's Avatar
Plus, 32" is supposedly the stock ride height for the front; stock height for the rear is 34".
N2, I might have to crawl under and take some pics, since I don't really know what I'm looking at under there...I mean, you guys will know a lot better than me whether you're looking at stock equipment or not.
Old 04-15-2009, 07:27 PM   #6
jb1016
jb1016's Avatar
All right, here's what I got...
Name:  2009_04150015 (Small).JPG
Name:  2009_04150016 (Small).JPG
Name:  2009_04150017 (Small).JPG
Old 04-15-2009, 07:33 PM   #7
STEPPED 69
STEPPED 69's Avatar
you have an aftermarket lowering shackle
STEPPED 69 is offline   Reply With Quote
Old 04-15-2009, 07:47 PM   #8
jb1016
jb1016's Avatar
the main thing in the second pic?
Old 04-15-2009, 08:19 PM   #9
andrewmp6
Yes the thing with all the holes holding the leaf spring that is a shackle.Its probably got a level kit on it which is why its level.
Old 04-15-2009, 08:29 PM   #10
jb1016
jb1016's Avatar
Thanks for the help guys. And thanks for not laughing at me too hard
Old 04-15-2009, 10:52 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
We are all here to learn, bro. If your shackle was stock it would be much shorter and wouldn't have all the holes in it.
Two of the holes are for adjustment, the others are there cause it looks cool..
Articles-
"Refining Sierra"
Old 04-16-2009, 07:18 AM   #12
entourageguy
Yellow truck club
entourageguy's Avatar
Usually with the lowering shackle there is a wedge for the leaf spring mount to correct pinion angle. How does it drive?
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 04-17-2009, 02:03 PM   #13
jb1016
jb1016's Avatar
Originally Posted by entourageguy View Post
How does it drive?
A little bit like a buckboard It's definitely rougher than stock; even small bumps will shake me up pretty good and make loud crashing noises.
Old 05-12-2009, 01:00 PM   #14
cleidus88
where can i buy some of those shackles? I'm wanting to level mine as well or is there a better way
cleidus88 is offline   Reply With Quote
Old 05-12-2009, 01:40 PM   #15
aggie91
I'm just glad to be here!
aggie91's Avatar
One thing that I noticed on your picture of the shackel is that it is installed backwards. The "open" side the shackel should be facing the spring. Part of the rough ride could be the shackel bottoming out against the spring as it flexes and moves. The other could be the rear end housing hitting the bump stop on the frame.
If you do not like the level look, you could move the spring eye down one hole on the shackel and get about one inch of rise on the rear end.
Either way, I would flip the shackel around.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
