Old 04-15-2009, 07:11 AM   #1
70-Chevy
-Chris
70-Chevy's Avatar
87 Blazer shuts off....
When the truck is driving in a straight direction the truck runs fine, but when a hard left or right turn is made, the truck shuts off. Once the truck is back straight, the truck starts up and takes off fine.
I am guessing that this problem is most likely in the steering column which is tight and not sloppy at all.
Do you guys have any insight or possible reasoning for this problem?
Thanks,
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 04-15-2009, 08:36 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: 87 Blazer shuts off....
Ok when I was reading this I was thing battrey. Try this if you are sitting in one spot and you turn it left to right dose it shut off? If not I would say a back ground or it could be a battrey.
Trav
tvblazer78 is offline   Reply With Quote
Old 04-15-2009, 02:34 PM   #3
70-Chevy
-Chris
70-Chevy's Avatar
If the truck is sitting in one spot not moving and the steering wheel is turned all the way to the left or right, then it does still shut off.
Another thing, since this is a tilt wheel column, the truck only does this shutting off thing when the steering wheel is all the way up. When the wheel is down to its lowest position the truck drives and turns fine without shutting off.
So I am basically assuming this is in the steering column, any idea on what part it may be?
thanks again for all the help.
Old 04-16-2009, 02:56 AM   #4
factory2wdblazer's
factory2wdblazer's's Avatar
you forsure have a short in your colume some where, the best thing to do is change the colume...........i had a to change a colume on my monte had a simular prob, when i would put the car in drive the horn would go off. even when i put it back it park. the horn would also go off when i would tilt the wheel up or down it would go off..........i messed with it and messed with it intill i finaly said f- it i'll try another colume it has to be the colume. picked up another colume come's to find out that fixed the prob so... i had a short some where in there never figured out where,.....
factory2wdblazer's is offline   Reply With Quote
Old 04-16-2009, 02:36 PM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Yep it sounds like your colume has had it..
