Old 04-15-2009, 10:03 PM   #1
slammin67
slammin67's Avatar
frame swap
Was just woundering if a 73-87 swb frame will swap on a 67-72 chevy swb 2wd...does any one know
slammin67 is offline   Reply With Quote
Old 04-15-2009, 10:34 PM   #2
BP68
BP68's Avatar
Re: frame swap
I have a 70 GMC with C10 front fenders on what appears to be a mid 80's frame. I don't know for sure on year of frame, but it is not a 67-72 frame.
The core support mounts are too far forward and the bed mounts have wood between them and the bed (to match cab to bed?) I would say it is doable, but you would need to spend some time relocating the body/core support mounts to end up with a quality job, unlike this truck I bought for parts.
However, if I were you, I would look for a correct year frame.
P.s. I have a Swb 2wd frame with 6 lug setup and drum brakes front and rear I am planning on selling.
You can PM if interrested. It is located in Red Banks, MS (near Holly Springs) about 40 mins from Memphis, TN
fyi
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 04-15-2009, 10:46 PM   #3
OARNGESI
OARNGESI's Avatar
Re: frame swap
No it ill need a body lift and will lok strange
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-15-2009, 10:48 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: frame swap
the truck frames won't work. They have the bed kicked up where you need a flat frame. Plus, you'd need to shorten the wheel base. A burb frame is flat and doable, but still a bunch of work.
