Old 04-20-2009, 08:52 PM   #1
crapy67
White wall terror
crapy67's Avatar
How much can I drop my c10
How much can I drop my 71 c10 without changing my spindles? I want to go as low as possible without much fabrication as my truck only has 59000 miles on it and its my daily driver. Thanks in advance, Mark.
crapy67 is offline   Reply With Quote
Old 04-20-2009, 09:02 PM   #2
Ram-Man
Ram-Man's Avatar
Re: How much can I drop my c10
If you are thinking just coils all around I think the max you can buy is 3/5. You could add lowering blocks in the rear to gain a little more than 5". Any more in the front you would need drop spindels also.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 04-20-2009, 09:05 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I can't tellyea yet but I'm dropping mine as low as it can ......I don't know what stock is but with no work to the front and just bags on my lwb fleetside the tailgate is 13" from the ground when it's open I'm waiting for my plates and bags for the front and am going to do that but plan on cutting my lower a arms for cup and then the X memeber will lay on the ground......right now it's 12" up
so I guess I would like to hear also then measure mine to see how close they are
jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-20-2009, 10:03 PM   #4
texanidiot25
Eat My Rust
texanidiot25's Avatar
3inches in front is pushing it, and 4-5 inches in back was pushing it in my case.
texanidiot25 is offline   Reply With Quote
Old 04-21-2009, 12:19 AM   #5
jpmanyhearts
frankenstien Fabrications
This might be irrelevant but this is as low as you can go period lol
jpmanyhearts is offline   Reply With Quote
Old 04-21-2009, 06:19 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
In the front, 3 inches is generally as far as you can drop it with a spring and get the alignment back into spec.
In the rear, 6 inches is pretty common with springs only. More than that and you really need a c notch.
In reference to the fellow above who mentioned a 5 inch springs in conjunction with a block. I feel that is not the best way. Basically, rear springs cost the same regardless of the drop. A 5 inch spring cost the same as a 6 incher. It doesn't make sense to buy a spring then lowering block stuff to go that extra inch. You'd be money ahead to just buy the 6 inch spring in the first place.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-21-2009, 02:25 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This is the rule of thumb that I follow as well...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-21-2009, 03:12 PM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
Originally Posted by jpmanyhearts View Post
This might be irrelevant but this is as low as you can go period lol YouTube - travis` s bodydropped 70 chevy truck ...IF CUSTOM
Never thought I would say this but that is to low to drive lol
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 04-21-2009, 03:39 PM   #9
see ten
WTB this ad
see ten's Avatar
If you want to go as low as possible without major fabrication, you should really consider using drop spindles. I think that a 2.5" spindle combined with a 1" drop coil in the front looks well proportioned to 6" rear springs.
If you haven't seen it already here's a thread I started last week showing how we did this same drop.
http://67-72chevytrucks.com/vboard/s...light=Saturday
see ten is offline   Reply With Quote
