Old 04-21-2009, 04:15 AM   #1
bumslie75
bumslie75's Avatar
Post Slow windows
Ok so my 87 has power windows, but for some reason both the drivers and the passenger windows go really slow or not even at all down or up do they need a new motor or is there a cheap and easy way to fix them? Also thanks for all your guys help i dont know what i would do with out you
bumslie75 is offline   Reply With Quote
Old 04-21-2009, 04:32 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Slow windows
First check if the windows are properly seated in the channels. Remove the door panel and grease the rails. Use a lithium based grease. Its thinner and lighter.
Upgrade to a 100 or 120 amp alternator. You can find them on 84-86 Camaros. The alternators will have V-belt pulleys. You can upgraded your current alternator up to 120 for only a few bucks if you do the work yourself. If you want extreme like me, I installed an 08 145 amp alternator!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-21-2009, 10:01 AM   #3
85Bowtie
85Bowtie's Avatar
Re: Slow windows
Your trucks an '87. most likely it's time to replace those old window motors.
On the cheap side, you could take them out and clean them with some electrical cleaner real good, sometimes they get gummed up.
Most likely, it's just time to replace them, $45 or so a piece.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 04-21-2009, 10:14 AM   #4
chevymotocross
chevymotocross's Avatar
Re: Slow windows
I replaced both my motors on my 87. They are just as fast as the newer vehicles.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 04-21-2009, 01:27 PM   #5
73chevyman
73chevyman's Avatar
Re: Slow windows
thats the first sign that the motors are warn out. time to replace. you can do all the other things every-1 else has said about the altinator up grade. if it were me I just get new motors and call it a day good luck
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-22-2009, 02:08 AM   #6
bumslie75
bumslie75's Avatar
Re: Slow windows
Anyone know of a place i can get new motors or if ones from a newer truck would fit i have an 87
Old 04-22-2009, 02:48 AM   #7
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Slow windows
also check for bad grounds and lose connections, I was only getting 7 volts to motor, and with a jumper box they would roll up just fine, so I switched to manual, then half a year later I was tired of my faulty so I rewired it
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-22-2009, 02:49 AM   #8
Manbearpig
Manbearpig's Avatar
Re: Slow windows
I hear putting relays on them speeds them up
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 04-22-2009, 08:04 AM   #9
85Bowtie
85Bowtie's Avatar
Re: Slow windows
Right here...
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=16
Old 04-22-2009, 09:29 AM   #10
dropd80s
dropd80s's Avatar
Re: Slow windows
I put relays on my origional 84 motors and they were very fast. Cheeper than buying new motors, worst case your out a couple bucks.
dropd80s is offline   Reply With Quote
Old 04-22-2009, 11:30 AM   #11
Damien
Damien's Avatar
Re: Slow windows
Auto parts store: NAPA, Advance, Carquest, ect
The motors from Auto Zone are cheap, both in price and build quality.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
