Old 04-21-2009, 06:24 PM   #1
Normy71
5.3 swap question Z71
Hi
I have found a 2006 GMC Z71 5.3 4x4 donor vehicle
before I purchase this what has to be done to the drive train before I install it to my 71 GMC long box? how do I deal with the transfer case? as my pickup is 2wd
I know I need to change motor mounts and deal with all the wiring
Thank You
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 04-21-2009, 10:11 PM   #2
Normy71
Re: 5.3 swap question Z71
Anyone?
Old 04-21-2009, 10:46 PM   #3
egressin
very interested in similar info im lookin to stay with 2wd though.
on another note my truck has an 86 frame already. it looks stock except for the suspension obviously. so i would imagine it couldnt b that complicated but i also am not scared of any project just the funding for it.
egressin is offline   Reply With Quote
Old 04-22-2009, 01:25 AM   #4
kamikazekyle05
kamikazekyle05's Avatar
You would probably have to move the transfercase crossmember, and figure out a way to get the pushbutton 4wd to work (assuming its push button). I think someone on here did a gen III 4wd swap, someone will chime in im sure
kamikazekyle05 is offline   Reply With Quote
Old 04-22-2009, 01:38 AM   #5
jbristo67
resident oilfield trash
jbristo67's Avatar
He wants to do away with the transfer case. His truck is a 2 wheel drive. I think you might be able to take it off and put a reg tail on it. I dont know for sure though
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 04-22-2009, 06:06 AM   #6
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Normy, You would be better off one of two ways:
1. Keep the entire frame/running gear and have your truck 4wd. This would make the swap a lot more simple. (not simple, just 'more' simple)
2. (What I'd do) Look for another donor thats 2wd, try to get the whole vechicle
Everything on that truck is computer controlled and unless you are very electrical savvy or have lots of $$ it will be much more difficult with a 4wd donor,jmo
chuckmc8 is offline   Reply With Quote
Old 04-22-2009, 10:06 AM   #7
kamikazekyle05
O lol, i didnt read it right. You have to swap the tail in the transmission out for a 2wd one.
Old 04-22-2009, 01:02 PM   #8
You can swap the tail housing as mentioned, but also as chuckmc8 mentioned, the computer is setup for a 4wd configured truck, so you would need it reprogrammed or as mentioned look for a complete 2wd truck to raid for parts.
Old 04-22-2009, 01:40 PM   #9
BustedTruck
BustedTruck's Avatar
You can't just put the extension housing on. You will have to change the output shaft. You also need to figure out how to get fuel to the engine and have theft theft system flashed out of the pcm.
BustedTruck is offline   Reply With Quote
Old 04-22-2009, 02:33 PM   #10
Normy71
Looks like the 4WD trans will not work with out a tail shaft being added to it .The transmission would have to be stripped and tail piece parts added to it which would cost a lot of $.
I cannot seem to find a tail piece adapter that would go in place transfer case.
looks like I should keep looking for a new donor truck that is a 2WD, or use this engine and find a new 2wd transmission.
Old 04-22-2009, 03:09 PM   #11
drtwhls
Thumbs up Re: 5.3 swap question Z71
the engine install isn't too bad on a 2wd. You have 2 options. Order the ECE motormounts or get a set of LS1 adaper plates that will utilize your stock motor mounts. You'll also need to do some research on which oil pan to use... I think the truck pan is the preffered on our 2wd trucks. Oh yeah, finding the right manifolds or headers seems to be tricky too, unless you are willing to hack your frame...
I am finishing the mock up of my LQ4 into a 4wd chassis. I used the adapter plates because the ECE plates are 2wd specific. I had to modify the crossmember to work. The a/c still requires a solution on my build, but I am almost there
You definitely need a 2wd transmission, I assume that you'll be using the stock comuter with the 4l60E/4l80e. The complete 2wd tranny won't require any additional mods like a 4wd tranny (i.e. tail shaft, speed sensors, etc).
LS1truck.com is a great site for information, the member redheartbeat has a huge wealth of information about the entire swap and who has the right parts.
Good luck!
drtwhls is offline   Reply With Quote
Old 04-22-2009, 03:32 PM   #12
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I thought you couldn't change tail shafts on these tranys. You would have to just have the right application. A 2wd trany for a 2wd and a 4wd trany for a 4wd. Am I right here. I thought is wasn't like the older transmissions.
LOW DOUGH is offline   Reply With Quote
Old 04-22-2009, 09:24 PM   #13
boostat4500
Tail shafts can be changed. My buddy adapted his 2WD 4L60E to a 71 FJ Cruiser T-case. Still would be easier though to just find a 2WD tranny.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 04-22-2009, 10:23 PM   #14
68 short step
the 2wd and the 4wd output shafts are diffrent.....so you cant just swap out the tail cone or tail housings......
but IMO it would be easier/cheaper to find the tranny for your application, instead of converting it...
68 short step is offline   Reply With Quote
Old 04-23-2009, 09:43 AM   #15
Normy71
Thanks Guy's
I decided with help from this great site to let the 4x4 donor truck go to someone else and look for a 2wd 5.3
Again
Old 04-23-2009, 02:06 PM   #16
ERASER5
ERASER5's Avatar
Hmm... And here I am thinking of putting an entire 5.3,trans, and transfer case under my 2 wheel drive. Why? I work my truck. 4Lo is 4Lo no matter if the fronts are engaged. Just my weird thoughts.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-23-2009, 02:12 PM   #17
Normy71
Good point!
How would you hook up the shift?
Old 04-24-2009, 08:08 PM   #18
ERASER5
ERASER5's Avatar
Don't know. But if I had the entire truck, I am sure I could come up with something. The switch is there right? Wiring diagrams and planning is the place to start.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 04-24-2009, 11:24 PM   #19
boostat4500
Stay away from the push button t-case. When I first did the swap in my truck, that's what I had, NP246. The problem is they are full time 4wd. There is no way to disconnect power to the front drive shaft. On a stock height truck it might work better than mine however. I have since swapped to a mechanical linkage t-case out of the same year (2001) truck and it's much nicer.
Old 04-24-2009, 11:36 PM   #20
chadio72
Truck Enthusiast
chadio72's Avatar
I'm beginning a similar project, only my 68 cab is going on a 01 gmc k1500 chassis. I will be starting a build thread on it soon, this is a big project. chop the frame, fab mounts, retain all electronics, a/c/ etc....
chadio72 is offline   Reply With Quote
Old 04-28-2009, 09:43 AM   #21
Normy71
chadio72 sounds like we have the same Idea's
Welcome to this site lots of great people and info
I have learned lots in the short time I have been on this site.
chadio72 send me a message and lets swap some idea's
Old 04-28-2009, 10:13 AM   #22
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Change motor over to a carb, hei dist, then you could loose the wireing harness, get a bellhouseing addaptor run a turbo 400 and call it a day. My son and i are doing a carb on a 6.0 with a turbo 400 trans......
1971 GMC SHORTY is offline   Reply With Quote
Old 04-28-2009, 12:13 PM   #23
chadio72
Truck Enthusiast
chadio72's Avatar
if i have problems with electronics, i will carb it, but i am a former dealer tech, i know the computer systems fairly well. my only worry is the security system. as long as all switches and sensors are retained, i should be ok.
Old 04-28-2009, 12:22 PM   #24
chadio72
Truck Enthusiast
chadio72's Avatar
i want to retain the 01 ac system, not sure yet how i am going to make that happen yet, a lot of custom work on the hvac box probly. this truck will be all modern under 68 sheetmetal. i plan on grafting the ins. cluster into an old dash panel, i will post pics when it happens
Old 04-28-2009, 01:30 PM   #25
brad_man_72
the boat guy
brad_man_72's Avatar
something i saw on another site $800 for a carb intake, then you still need to control the spark.
why not spend the $1200+ for a carb swap on doing the computer and harness. keep the low end torque and fuel savings?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
