Old 04-21-2009, 10:56 PM   #1
txriverrat
Help! installing distributor, won't drop in
Hey guys,
I bought one of the Skip White HEI distributors off eBay, got it in the mail today and went to drop it in, but it won't sit down all the way. It feels like it's all the way in, but there's still about 3/8" gap between it and the block. I tried moving the crank while my dad wiggled the dist, but it wouldn't drop. Please help! Do I need to keep rotating the engine till the dist. drops in the rest of the way? I was wary of doing that and throwing the timing way out of whack...I dunno what else to do though, not much experience with v8 engines, kind of learning as I go.
Thanks,
Cole
edit: truck is a 69 with a small block 350
txriverrat is offline   Reply With Quote
Old 04-21-2009, 11:06 PM   #2
LowBow
Self Made Hundredaire
LowBow's Avatar
Re: Help! installing distributor, won't drop in
your oil pump is probably interfering. take a long screwdriver and turn it (a little half moon looking thing below the distributor) until it lines up. you just pull the dizzy out and try to see where the key on it would fit into the oil pump shaft, should work!
'79 corvette - all original 49k car!
'03 Z71 ECSB - gas hog
'57 Belair 2 door hardtop. Love of my life!
LowBow is offline   Reply With Quote
Old 04-21-2009, 11:09 PM   #3
berencam
berencam's Avatar
there is a key on the bottom of the dizzy, it has to match up to the oil rod. you can take a long flat screwdriver and move the oil rod a bit to the left or right. Make sure the 1st piston is at tdc and on fire stroke, and just keep stabbing one tooth over till you get it in. then mark the dizzy on the post that the rotor points too, thats your first plug.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-21-2009, 11:09 PM   #4
Skirkpat
Skirkpat's Avatar
Grab the rotor, if it won't turn that means it is engaged in the gear on the cam, all you need to do is turn the engine over a few times and it will drop in.
Skirkpat is offline   Reply With Quote
Old 04-21-2009, 11:10 PM   #5
berencam
berencam's Avatar
beat me too it lol
Old 04-21-2009, 11:10 PM   #6
drivethechevy
drivethechevy's Avatar
what intake are you running? some older edlebrock intakes and a few other aftermarket aluminum intakes are not made to accept hei distributers and will either need to be swaped out for a different intake, or you can have in machined out and have a spacer made to acomodate for the gap
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 04-21-2009, 11:16 PM   #7
berencam
berencam's Avatar
skip whites hei dizzy's come with the spacer
Old 04-21-2009, 11:28 PM   #8
txriverrat
WOW,
Thanks for all the quick replies guys!
LowBow, I will try turning the oil pump tomorrow. That's probably the culprit, I just didn't know that you could turn it with a screwdriver. Cool trick, thanks for sharing!
Drivethechevy, I am not running an aftermarket intake manifold. So far as I know this motor is totally stock. Thanks for the info though, I had been considering an edlebrock intake/carb swap in the future. Looks like I'll have to do more research!
Thanks again guys!
Cole
Old 04-21-2009, 11:29 PM   #9
dznucks
dznucks's Avatar
i took my old dizzy apart and used the shaft with the gear pinned back on as a tool to turn the oil pump shaft. when removing a dizzy, i have found that if you grab the rotor and turn it counterclockwise as you remove the dizzy, you wont have the problem.
dznucks is offline   Reply With Quote
Old 04-22-2009, 12:49 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Exactly, have someone put there hand on top of the cap, and then bump the engine over a time or two, it'll drop right in.
Old 04-22-2009, 07:14 AM   #11
68C15
blood type; Retumbo
68C15's Avatar
putting the cap on is a good way to keep your fingers away from the rotor. a turning rotor can make a mess out of a finger.
68C15 is offline   Reply With Quote
Old 04-22-2009, 10:40 AM   #12
1320tech
if you hold the top of the dist with the cap on while some one bumps it over make sure dist. is not pluged in or it will light you up and ruin your day ask me how i know.
1320tech is offline   Reply With Quote
Old 04-22-2009, 11:50 AM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
That's a new one on me, in 50 years of working on chevy smallblocks I have never seen a spacer under the distributor on points or HEI units on stock or aftermarket manifolds. Could someone post a picture.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-22-2009, 11:51 AM   #14
Sinister
Between Trucks...
Sinister's Avatar
If you take a screwdriver and aim the slot of the pump drive shaft at the #7 intake valve, (about 10 o'clock, looking down on it), it'll drop right in. This assumes your at TDC.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
