Old 04-21-2009, 08:05 PM   #1
bigblock73
yeller
bigblock73's Avatar
steering column guru's, need your help
My blinker lever, or I should say the part it connects to in the column...is broken. I am trying to get to that part inside the column, and can't seem to figure out how to get the metal plate off that you see in the following picture. I have tried lightly prying it up..but it does not want to budge, and I don't want to break it. How in the world do you remove it?
Also, my column is non-tilit, automotic. Is the part I need called the turn signal cancelling switch, or what? Anyone have a spare? LoL!
bigblock73 is offline   Reply With Quote
Old 04-21-2009, 08:38 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: steering column guru's, need your help
OK, I got it off and the damaged part out. There was a retaining ring holding that piece on, what a PITA that little thing was.
Old 04-21-2009, 08:58 PM   #3
impalamark
impalamark's Avatar
yea there is a tool available at most parts stores used to
take that retainer ring out under $10 and worth it
Mark
the avatar was my 62 I owned for 27 years
84 chevy short short bed black
84 gmc long bed copper/ buckskin
88 chevy k5 blazer white
Life's short make the most of it
Mark aka impalmark
impalamark is offline   Reply With Quote
Old 04-21-2009, 10:52 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Jeff your probably going to need to find that tool. If I remember correctly it is darn near impossible to get the clip back on with out it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-21-2009, 11:02 PM   #5
Longhorn321
Size Matters
Longhorn321's Avatar
Yes..darn near. I actually did wrestle the thing back together but I won't do it again without the tool.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 04-21-2009, 11:06 PM   #6
asphaltburner
asphaltburner's Avatar
Yo!
If you search "horn", "turn signal", or "steering column" on this forum, you'll find my new pictorial. Check this link:
http://67-72chevytrucks.com/vboard/s...00#post3225400
A pic of the tool and step by step re-installation instructions are found there. It should answer any questions you might have.
"C" clip holds the lockplate in place. You may need a new one unless the old one popped out undamaged.
Please add any additional info you feel others might need to the linked post,...I hope it can be used as a data base for everyone in the future.
Thanks, Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 04-21-2009, 11:33 PM   #7
bigblock73
yeller
bigblock73's Avatar
Todd, that is great!!! Thanks!
I did get the clip out without damaging it (I hope), so it should go back in no sweat. (I hope). If it is damaged, is that another NAPA part?
How hard were the metal parts to remove from the old turn signal switch and put on the new one? Springs look easy, the others look like a pain.
Old 04-21-2009, 11:43 PM   #8
asphaltburner
The turn signal switch is sold as a unit. NAPA has it,...I could look up the cost for you but don't remember right off. Cheap. Goes in with three screws and the extension arm bolts on with just one screw (see second pic in my pictorial).
"C" clip I have not had to locate,...YET! But I'd bet junkyards and parts stores would have the item,...fits my '76 Camaro as well,...probably all Chevys of the era.
Todd.
Old 04-21-2009, 11:44 PM   #9
Longhorn321
Size Matters
IIRC, the only challenge is the clip. The rest is a piece of cake.
...WOOOO HOOOO!!!!
Old 04-21-2009, 11:46 PM   #10
asphaltburner
OK,...call me OLD! What the hell does IIRC mean,...sorry all. Todd.
Old 04-21-2009, 11:57 PM   #11
bigblock73
yeller
bigblock73's Avatar
Old 04-22-2009, 12:23 AM   #12
elwoods76
Just Cruizin
elwoods76's Avatar
Hey Big block73, I have a couple of 4 speed columns that I have no plans for as of yet, if you need something and can't find it at the parts store pm and I should be able to tear into one of them and get you parts. I have been there before trying to get that apart without the lock plate removal tool(best $14 I ever spent).
elwoods76 is offline   Reply With Quote
Old 04-22-2009, 11:38 AM   #13
Damien
Damien's Avatar
Lisle makes them. Check the parts stores. They are very common. Here is a link to Lisle. http://www.lislecorp.com/tool_detail.cfm?detail=1128
The spring in there is like trying to compres a valve spring by hand. It can be don, but the tool makes it a five minute job, versus an hour.
I will let you use mine if you want to come get it.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 04-22-2009, 12:22 PM   #14
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Jeff, get the tool, it makes it much easier to get it on/off with it.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-22-2009, 12:27 PM   #15
bigblock73
yeller
bigblock73's Avatar
Alright, going to NAPA tonight to get the part and tool.
I thought the install would go easier...but I'll get it just in case.
Thanks again for the help.
Old 04-22-2009, 12:35 PM   #16
Damien
Damien's Avatar
The install is the worst part without it!
Old 04-22-2009, 12:51 PM   #17
Captkaos
Captkaos's Avatar
you will spend a long time trying to keep pressure on it to get that ring back in, getting it out is the easier part.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-22-2009, 02:04 PM   #18
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Oh you mean its not fun compressing the valve spring without the lock plate tool...? lol
Jeff you can reuse the retaining ring but the book says to replace them. You will also need to unplug the turn signal wires so you can get the old turn signal assy out. That would be the yellowish/clear plastic part with the 3/4 screws holding it in place.
The signal canceling switch is the green plastic piece. That hooks also is used for your horn button.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-22-2009, 03:35 PM   #19
bigblock73
yeller
bigblock73's Avatar
I got the signal assembly out without having to unplug the wires, it was a tad tricky, but I got it.
Old 04-30-2009, 01:53 PM   #20
bigblock73
yeller
bigblock73's Avatar
OK folks, update on this. NAPA did not carry just the piece I needed (the piece the turn signal level screws into...I guess it is called the turn signal switch lever cam)...so I orded one from a resto company and it got here Wednesday. It is advertised to fit 73-92 non-tilt...and that is what I have. It looks identical for the most part except the area where the turn signal lever screws into is different. My original broken one had a small opening in it that the srew holding the lever on screwed into. The new one had a larger octagnal opening and appears as if there is a piece that slides in there that the screw goes into.
Does anyone know what I am talking about, or can help me out here?
Thanks!
Old 04-30-2009, 02:03 PM   #21
elwoods76
Just Cruizin
elwoods76's Avatar
I will take the part out an extra column that isn't a tilt to compare. Show us the pics so we can see the differences?
Old 04-30-2009, 02:45 PM   #22
bigblock73
yeller
bigblock73's Avatar
OK, here are the old and new pics. I thought the new hole was octagnal, but that is the shaft behind it...the new hole is just quite a bit larger than the old one.
I just need to get the signal lever to screw down and work, everything else appears to be OK.
Old 04-30-2009, 11:41 PM   #23
elwoods76
Just Cruizin
elwoods76's Avatar
Let me know what you think about this. I can tear it down even further, just ran out of time cause of helping another buddy.
