#826 |
1961 crewcab
Re: My 1965 build thread
I wander what and how much I could get done if I could stay off this forum. I have 2 addictions....this forum and my truck.
-Amen,brother. |
#827 |
Schlongbed MEMBER (heh)#15
Awesome thread. I've learned a lot.
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
#828 |
Shloooooong bed member #2
Alan,
You must have made ole JOEKIP mad what's up with that.... ![]() I wouild most definitly make sure the lifters were lubed and free before you start the rebuild. things are looking good.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
#829 |
Registerd User
Lookin good Alan. Is the motor stock?
#830 |
I believe Alan said before that it is a 383ci
#831 | ||
1 thing at a time is progress.
![]() ![]() Quote:
![]() Joe's right it's just a budget 383 nothing fancy. Nice memory:chevy:
Alan
Philippians 2:14-16 |
#832 |
![]() ![]() Join Date: Jul 2002
Alan, I caught the Joekip thing early and set him packing. I just didn't get a chance to input here or back to you because of work. He definitely was a real winner.
So are any of us working on our trucks or we just kickin back in the AC surfin? ![]()
#833 |
Daring to be Different
Hey Allan, just a tip when you install the oil pump, and put the oil pick up strainer, on tack weld it on the pump. A lot of engine builders do it. I do.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#834 | |
I'm out in the shop working on my engine, checking this forum periodically. Thanks Dennis, I learned that several years ago. But, someone might read this that doesn't know. Thanks for watching out for me. As a matter of fact that is what I'm fixin' to do next. If I can figure this lifter issue out I'll feel better. I posted a thread in the engine section and I also have a call into my cousin. He builds some nice 406 SBC's. I figure I'll pick his brain a little.
Alan
#835 |
I'm chilling in the A/C
we hit low-mid 90's today ![]() A big thanks to ya Bill, and everyone else for all you guys do!!!
#836 | |
#837 |
Rods
![]() Join Date: Nov 2002
if your lifters did bleed down. just pull them out and soak them in oil overnight.guess i was a little slow
#838 | |
#839 |
Thanks for the input on lifters. My cousin called me back plus I got some help from the engine forum to reinforce what my cousin said. I over tightened the lifters by about a round and waited for the oil to bled out of it. That was the problem they were full of oil. It was simple but confused me
![]() I found out my cousin has a 68 camaro with a 540 Kieth Black engine. He's coming to the next cruise in. I want a ride. ![]() Also found out today that the federal government had the oil makers remove certain components like zinc. Because the stuff was plugging catylitic converters. That has resulted in alot of flat tappet cams failing. I've heard it from 3 different people in the past few days (2 engine builders). My cousin runs rotella diesel oil. It still has the ingredients in it. Has anyone else heard of this? Or you could ad this for about $12 a bottle. One engine builder uses it, I think I would use rotella ![]() Got my oil pump and pan on tonight. ![]()
Alan
#840 |
1961 crewcab
there was a bunch of different threads about the zinc oil on the h.a.m.b., just search oil,zinc ,and hamb on google, and you should get some of them.
#841 |
Hollister, CA.
![]() Join Date: Sep 2006
Alan, its coming together, looking good man !!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#842 |
I always coated everything with assembly lube. Never had a problem. But it's been a long, long, long time since I use to rebuild engines. With all these new chemicals out now, I wouldn't know what's the best to use anymore.
#843 |
Its Deja Vu time again
ooooooohhh Pictures. I'm paying attention again.
#844 |
We always use plenty of assembly lube and this stuff:
http://www.daymotorsports.com/produc...N_OIL_ADDITIVE in our 383 flat tappet race motors, 13:1 compression with a good size cam and lots of spring pressure. It seems to be working good and we just use conventional oil. From what I've heard, even the diesel oils are now under the thumb of the government and may not contain all of the chemicals that they used to. |
#845 | |||
Sorry, I lost you with all of the words. ![]() ![]() ![]() Quote:
OK, I'm a dumb a$$, kind of. I installed the oil pump and pan last night. I went to adjust the valves tonight. I rotated the crank and it came to a solid stop. What the heck I thought. I removed the pan and found the Melling M-55A oil pump in the way of the crank counter weight. I should have spun it over last night. (Hind sight is a B&tch) I then looked in the box that it came in and found a little note. It reads "Any high performance application especially those using solid motor mounts require the installation of an M Select performance oil pump" Don't know if that applies to me or not. ![]()
Alan
#846 |
Sunburst C10!!!
ive never seen anything like that are the counterweights bigger on the 383 crank who is the manufacturer
Gage 1967 C10 Shortbed Stepside |
#847 |
Sunburst C10!!!
it shows the pump is a z28 pump the z28s came with a 301 dz which is a smaller crank and smaller counterweights so that could be your problem
#848 |
The 383 crank is actually a 400 crank. There are some clearance issues with the block and rods and the oil pan (sometimes). I have ran this engine before the way it is except for the new oil pump. I took the oil pump off for another engine if anyone is wondering.
Alan
#849 |
SSN 706
If I knew anything about anything I would offer advice, but I don't. So I'll just sit here and watch. Good luck I know you'll get it figured out. Can't wait to start on my engine.
#850 |
I wonder if that oil pump is for a 350 crank. Check and see if the 400 has a different part number for it.
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
