Old 04-23-2009, 12:43 PM   #51
Charlesdur
Charlesdur's Avatar
Re: 1971 3/4 swap to 1/2 ton
It has some farm tires on it. I know that the rear tires are 33's, but not sure about the front. I did have to remove the wheel wells also since it would rub when I made sharp turns. The ride is good on the highway, but if you hit a big bump you will feel it, but nothing like the bouncy ride in a car with hydros. I haven't done any other work to it lately, but summer is around the corner and the nights will be long. I do have an extra pair of new Monroe air shocks for the truck that I will sell for $40.00. I made a mistake on my order and ordered 2 sets and never returned them. You shouldn't need them though unless you also have 33 inch tires.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
Charlesdur is offline   Reply With Quote
Old 04-23-2009, 12:48 PM   #52
Charlesdur
Charlesdur's Avatar
Also you will not have a nice alignment unless you get the drop spindles or shim it out. I personally dont care about that though since it still drives straight and I dont drive it enough to wear out the tires.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
Old 04-23-2009, 01:11 PM   #53
ERASER5
ERASER5's Avatar
Nice truck, and good call on keeping the D-60. Nobody mentioned to you that if you swapped in a 12 bolt, your drive shaft would have been too short by 1.75". The slip joint would/could pop apart.
Again, nice truck.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-23-2009, 01:37 PM   #54
souza777
souza777's Avatar
What do you mean shim it out? Is it something I need to do when I put the coil springs in? I planned on doing it this weekend.
souza777 is offline   Reply With Quote
Old 04-26-2009, 07:19 PM   #55
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
Charles..... Man oh man.... Your stance is leaving me speechless.
I have a 72' GMC 3/4 ton and have been stuck on whether or not to convert over to 5 lug.... I want to lower it and i can't afford bags.
It's crazy cuz' your truck looks just like mine only beautifully budget slammed and primer gray.
I painted wide whites on mine about a month ago and get about the same reaction you probably are except yours looks so damn sweet sitting that low.... Does your front tires rub at all when turning?
exmonkeypunk is offline   Reply With Quote
