newbie
whats the difference?
what is the difference between...?
700r4 t350 t400 |
Re: whats the difference?
th350 is the light duty 3 speed automatic
th400 is the heavy duty 3 speed automatic th700r4 is the light duty 4 speed Overdrive automatic |
Double 6's
but doesnt the turbo 400 have overdrive?
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
Garage wrench
in the later years gm made a 4L80, basically a TH400 with overdrive.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Cheyenne Super
At the risk of starting a transmission debate, I will say you should avoid the "heavy duty" TH400, and run away
(like a little girl from a frog weilding boy) from the overdrive 700-R4 because in original condition (not rebuilt w/heavy duty parts) they are both flawed and not very dependable. That's my past exp with them anyway. ![]() |
newbie
Is the 700R4 better if rebuilt? and about how much you think is it to rebuild?
And is it better on gas because it has more gears? |
#8 | ||
There are some variations in gear ratios even in the 3 speeds, but they are minimal. The TH400 takes a little more power to operate, so it is not the best choice for a lower powered engine, but I have never heard of anyone having reliability issues with them.
There are more choices in the Over-Drive automatics though. 4L60-E and the heavier duty 4L60-E HD have the lower first gears like the 700-r4. The 4L80-E has a higher first gear, more like the 3 speeds. Quote:
Cost is very relative. It depends upon your area. Yes, as long as you are geared correctly for the tire size you have, (and your intended road speed) the overdrive should gain you a noticable amount of mileage increase.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Kid's Mechanic
The only thing that i have heard about 400s that is the least bit bad has been some of the 4X4 guys knocking reverse out of them.And the two complaints came from from trucks that had (38s on one and 39.5s on the other)
newbie
I live on a hill and i drive up the Appalachian Mountains everyday. All i want is a transmission that i know will last and not die on the mountains.
I'm still learning about cars. So i don't know much. Last edited by dga93; 04-25-2009 at 11:01 PM. |
i love the 700r4.. i have a 90 700r4 in my blazer best automatic transmission avialible i think. over-drive transmission with the lock up converter, only up grade the transmission has is a corvette servo, the transmission shift's perfect. i beleave the 700r4 is way better then the turbo 350 & turbo 400..........just my 2 cent's..........700r4's/4l60's
TH350 ratio's:
1st: 2.52 |2nd: 1.52 |3rd: 1.00 |R: 1.93 TH400 ratio's: 1st: 2.48 |2nd: 1.48 |3rd: 1.00 |R: 2.00 700r4 ratio's: 1st: 3.06 |2nd: 1.62 |3rd: 1.00 |4th: 0.70 |R: 2.29
1972 GMC C10 |
#13 | |
That was funny.
1972 GMC C10 Last edited by LONGHAIR; 04-26-2009 at 10:43 AM. |
Cheyenne Super
Hey wtf is that thing? I can't even see what it is, maybe NASA has a screen big enough to see that but I sure don't.
#15 |
It actually pissed me off. Why? I don't know.
____________________________________ |
#16 |
Cheyenne Super
What did? huh? Oh yeah the big thing...
#17 |
I would change it to a smaller one but I can't edit it.
1972 GMC C10 |
#18 |
Cheyenne Super
#19 | |
Resized that huge thing into something much more "friendly". THat is 10% of the original size.....LOL
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 04-26-2009 at 10:44 AM. |
#20 |
Basically as far as reliability goes IMO none of the automatics are strong enough for me. I've broken them all in stock form..... with stock power engines.... I will say though for me the th400 lasted way longer than the others before needing work. They all do better after a quality rebuild and whatever updates/improvements have come out since it was last rebuilt. Think Upgrades....
#21 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
When the 700R4's first came out in these truck 27 years ago 1982, they did have issues. In 6 years (1987/88) all those that had issues were upgraded. If you have a 1982-1986 truck with an original 700R4 transmission that is still alive you aren't going to have any problems with it as it has probably been replaced already.
You can build one to handle a LOT of power, but if you start with a 1988 trans it already has all the good upgrades in them. Keep in mind most of the hard parts from a current 4L60E will go in a 700R4 (4L60) as they are the same transmission just one has a electronic valve body.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#22 | |
Cheyenne Super
Yeah they are great if they are pro built with stronger parts, I was thinkin he was looking to buy a stock truck, but I guess he should give us more details about what he's looking at and what he has to spend. |
#23 |
newbie
Do the 3 have all different bolt patterns?
and does it matter on the year of the motor in the truck? |
#24 |
my truck has a 700r4 out of a 84 (same with the 208 t-case) both seem to work fine i love the over drive with the 4.10's i can only imagine the milage suck it would have with a 3 speed auto or any tranny with a 1:1 only
i have noticed that you can not feel it shift when just cruising this kind of bugs me a bit because i can not tell if it is slipping or what? i plan on getting the vette servo and a shift kit (the fluid is nice and pink though ![]()
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels ![]() 2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost ![]() |
#25 |
newbie
O.k. So i have a 1978 c10 with a 350 and a dead slipping th350..
I don't have much to spend but i can save my money. I drive up a lot of mountains and highway driving is most of it. I want to know what would be my best way to go? And if the bolt pattern is the same thru all transmissions? I know so far if i get a 700r4 i would have to shorten the drive shaft but that's all i know. HELP! |
