Old 04-25-2009, 10:47 PM   #1
Bob B.
Speedometer with 4L80E
I have a question: Is there a slick way of using a stock speedometer with an electronic transmission such as the 4L60E, 4L80E, or maybe even the new 6L90? Thanks!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 04-25-2009, 11:05 PM   #2
bsgmcc20
Im afraid of purple hangers..
bsgmcc20's Avatar
Re: Speedometer with 4L80E
My buddy wayne said they have boxes you can convert them back to cable
#68. Install a mechanical tachograph or operate a mechanical speedometer on a vehicle equipped with an electronic speedometer signal (sensor). You can do it -- quickly and easily -- at a cost far below that of buying and installing drive gears in the transmission. You save on the cost of buying and installing electronic tachographs and speedometers.
Cable X lets you use popular, low cost mechanical tachographs such as Abbott, Argo, Sangamo, Servis Recorder and Veeder-Root, and mechanical speedometers such as Autometer, Clark Brothers, Datcon, Stewart Warner and Teleflex. It operates at accurate speeds -plus or minus 2%- on the most common OEM electronic speed signals, and is as easy to install as any electronic tachograph.
You save hours of downtime installing gears into the transmission, and you don't have to mess with troublesome, expensive and long cables. Cost $319.00
https://www.vermontsecure.com/cart.a...it=Add+to+Cart
just a bit much i would say
depends on what you wanna do.....
good luck
bsgmcc20 is offline   Reply With Quote
Old 04-26-2009, 12:16 AM   #3
mr48chev
mr48chev's Avatar
Check with this outfit. They should be able to fix you up.
http://www.transmissioncenter.net/sp...n_______va.htm
The site is full of good speedo drive info for just about any setup you might have too.
Old 04-26-2009, 11:37 PM   #4
Bob B.
Thanks!
