04-26-2009, 03:53 PM | #1 |
Window Channel Question
I replaced my regulator and removed the window channel screws to make it easier. The one on the door end has nothing to thread into now. Did this originally have a nut on the other end? I can't find that nut anywhere.
Thanks for the help, Chad |
04-26-2009, 06:49 PM | #2 |
The Older Generation
Re: Window Channel Question
The nut should be welded to the channel bracket. The channel is probably too far away from the back of the door for the screw to reach it. Roll the window down, loosen the two screws on the inside of the door and see if you can push back on the top of the channel and get the screw started.... LockDoc
04-26-2009, 07:56 PM | #3 |
The bolt actually fell off. I found it in the bottom of the door. I was able to get it back on finally. Thanks for the help.
Chad |
04-27-2009, 10:46 AM | #4 |
No problem, glad you got it fixed... LockDoc
