Old 04-27-2009, 10:49 AM   #1
truckincurt
for you who run a 383 stroker
just wondering what you guys are running for a carb on your 383... just finished my build on a 383 4 bolt main with a mild cam and dart pro alum heads with large valves i got a desktop dyno that says i should be running 530 lbs ft of torque ... so what are u running 650? 700? 750? mechanical secondaries? vacuum secondaries? thanks for everyones help
truckincurt is offline   Reply With Quote
Old 04-27-2009, 12:40 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: for you who run a 383 stroker
I would say 750 and buy a jet kit so you jet it for your likings..
tvblazer78 is offline   Reply With Quote
Old 04-27-2009, 12:59 PM   #3
Crush
Active Member
Crush's Avatar
I'm currently running a AVS 800 on mine (I had it on the shelf and the 600 that was on it needed a rebuild) and I had to jet it down a bit to make it run right..
If i had a choice I'd run a 700-750...like tvblazer78 said...buy a 750 and a jet kit and tune it...
D.M.C -FF-
Crush is offline   Reply With Quote
Old 04-28-2009, 10:19 AM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
Edelbrock 1407 (750cfm) here, tuned with a wideband o2. Knocked down 17mpg on my last tank.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-28-2009, 10:42 AM   #5
rodstored-72
chevy truck fan
rodstored-72's Avatar
i am the unusual one... iguess. i am running a holley 600cfm. i was told that it would help with getting more torque.
rodstored-72 is offline   Reply With Quote
Old 04-30-2009, 10:45 AM   #6
truckincurt
ya.. people have told me that if you want a low rpm torque motor to run a 650 but if you want to run 5 or 6 grand to run bigger like a 750 but idk i dont think my motor will last very long after anything over 4500-5000 because im running 11.0 compression ... everythings forged but idk what it can handel
Old 04-30-2009, 12:06 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
I run an Edelbrock 750 and I'm running jets and metering rods at the richer end of the charts. It came very lean out of the box. It works well though.
Your redline RPM as far the bottom end is concerned is all about rotating assembly and fastener strength.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-30-2009, 01:12 PM   #8
BruthaMan
US Army Veteran
BruthaMan's Avatar
I'm running an Edelbrock 1406 (600 CFM).
BruthaMan is offline   Reply With Quote
Old 04-30-2009, 01:15 PM   #9
07SSSC
07SSSC's Avatar
I run an Edelbrock 1411 (750 cfm) that was jetted down while playing at the local 1/8th mile drag strip.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline   Reply With Quote
