Old 03-20-2003, 09:38 PM   #1
Dads72
For possible future reference
Sent a post called "where did my heat go" and received zero replies.
Now I know why.
Here's the deal.
Shut the heat off under the hood using the valve on the passenger's side on the firewall. Wanted to get the heat back yesterday, so I moved the valve the other way.
No heat.
Checked today and found the fan/alternator belt was way loose.
The bolt that holds the alternator bracket to the block was broken. Everything had gradually shifted.
The water pump wasn't turning, hence - no heat.
Everything is fine now, but I don't want to remove a broken bolt in the head again. PITA.
Hope this helps someone down the road.
Dads72 is offline   Reply With Quote
Old 03-20-2003, 10:04 PM   #2
Purs
Got Big Block?
Purs's Avatar
thanks dad!
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 03-21-2003, 12:24 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
been there with the busted bolt in the head. Was actually starting to think about rotating the heads...might have been easier!
Old 03-21-2003, 09:33 AM   #4
Blue Beard
Blue Beard's Avatar
Hope it didn't run too long with that problem................don't want any other problems to come out of it..............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
