Old 04-28-2009, 11:15 AM   #1
RckyMntnKng
RckyMntnKng's Avatar
Identifying gearing....
Alot of the axles out there from years past are missing the Id-tag on the pumpkin listing the original ring gearing.
Can someone explain how to "count the teeth" or whatever it is you do, to identify the gear ratio in an unknown axle?
Thanks!
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 04-28-2009, 11:47 AM   #2
estig70
estig70's Avatar
Re: Identifying gearing....
Thanks!
Remove rearend cover, count number of teeth on the Ring gear (larger gear) and count number of teeth on the pinion gear. Divide number of teeth per ring gear by number of teeth per pinion gear and you get your gear ratio.
Eric
estig70 is offline   Reply With Quote
Old 04-28-2009, 11:50 AM   #3
RckyMntnKng
Much appreciated!
Old 04-28-2009, 11:57 AM   #4
Burt4x4
Burt4x4's Avatar
I forget the formula but look for a stamped number on the ring gear then google that number..somethign like 41:11 is 3.73ratio
I found this on google:
ratio 3.08 3.42 3.73 4.10 4.56 4.88 5.13 5.38
teeth 40-13 41-12 41-11 41-10 41-9 39-8 41-8 43-8
so 41-9 teeth is 4.56 ratio
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-28-2009, 12:14 PM   #5
RckyMntnKng
great.
So if you were changing from 4.10 to 4.56 that is only one less tooth on the pinion gear. Would you leave the ring gear the same.
Old 04-28-2009, 01:51 PM   #6
Burt4x4
Burt4x4's Avatar
No, you have to change both Ring & Pinion as a "set". Not only is the tooth count different but the angle of the teeth as well need to match
Old 04-28-2009, 01:52 PM   #7
RckyMntnKng
Of course they would make it that way!
Old 04-30-2009, 11:21 AM   #8
RckyMntnKng
Pulled the cover off my old d44 6 lug I had on the rear before my 14 bolt to try out the gear counting.
I came up with 43-14 or 3.07 gearing.
What do you call the other gears in there? I saw the ring and the pinion as well as 4 other gears in the center section.
Old 04-30-2009, 11:47 AM   #9
Burt4x4
Burt4x4's Avatar
The small gears is your differential (sp?) 'spider' gears. A cheep way to make a locker it to weld thoes gears togeather.
This is my old D60 rear, it has a Dana Powr-Lok posi/limitied slip diff in it.
Found this on google
Basic open diff, no traction devices used, factory OE type diff = One leg burnout
Old 04-30-2009, 12:11 PM   #10
estig70
estig70's Avatar
that is correct my friend. A little high for a 4x4 in my opinion, of course depends on what you use it for.
Eric
Old 04-30-2009, 07:04 PM   #11
LONGHAIR
Please, don't do this. Not only is it dangerous and destructive, it's just plain hard to drive on the street or anywhere else for that matter. It is hard to turn and makes the truck tend to "push" or "plow" instead of following the steering.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-01-2009, 09:24 AM   #12
Burt4x4
Burt4x4's Avatar
Very true, I have never had a "lincoln" locker (no clue why some call it that) hahaha and The guys I have seen run this only have it in the rear and are mostly off-road only rigs
Old 05-01-2009, 02:02 PM   #13
Yukon Jack
Yukon Jack's Avatar
The nickname came from people doing the welding with a Lincoln welder.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-01-2009, 02:47 PM   #14
Burt4x4
Burt4x4's Avatar
Well Duh! hahahahah
Just didn't put the connection in my head I guess!
THanks YJ
Have a good weekend!
Old 05-01-2009, 06:08 PM   #15
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
i love my "hobart" locker. i think saying that it is dangerous and destructive is way out of line. it is no different than a spool. in fact it behaves the exact same as the detroit locker, on and off the road, that was in the axle before i welded it up. it'll certainly wear your rear tires down twice as fast though.
bmeredith is offline   Reply With Quote
Old 05-01-2009, 07:31 PM   #16
LONGHAIR
It is not "out of line" at all....I have personally seen them fail. The vehicle will make a very hard jolt/jump to one side, it can also pull the steering wheel out of your hands. Is anyone or anything nearby?
Second, no one ever disassembles/degreases the entire unit in an "attempt" to do it as properly as possible.....though I don't believe it is possible. Those gears were not intended to be welded upon, they shatter when they fail, it is sudden. So, they end up getting welded right there in the housing with spatter and slag going everywhere...not good for the bearings or the ring and pinion.
Welded spiders do in fact act exactly like a spool (except the failure part) but that is NOT the same as a "Detroit Locker". "Lockers" are not spools, they do "unlock" one wheel to have "defferential action". This action is somewhat predictable, but you do need some experience with driving one.
BTW, I wouldn't run a spool on the street either......
Tire wear? double I don't know about, but it is certainly accelerated. Not to mention that you absolutely cannot stop that "squeeling" when turning on pavement, every turn every time. Do you want to have to explain that to the police? more than once?
