Old 04-28-2009, 02:03 PM   #201
lyrikz
PITbut
lyrikz's Avatar
Re: My build. Project Karma. 71 stepside.
Originally Posted by lyrikz View Post
Call lokar? That would be to easy. ahaha
BRB, i will let ya know what they say..
They didnt say anything.. Just, play with the lower lever... That was it. ahah
lyrikz is offline   Reply With Quote
Old 04-28-2009, 09:02 PM   #202
Riveted1
Tasty Cakes!
Riveted1's Avatar
You could do that all day long, but I don't know what that has to do w/the gear selector.
Well, better get busy!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-29-2009, 11:09 PM   #203
lyrikz
PITbut
lyrikz's Avatar
QUick little update... Starter related.
I just kind of stumbled upon this. I dont know if its new news or im just a late bloomer. I have a chevy 454. Its from an 81 chevy. The starter that came with it is huge. My headers literally touched my starter.
I was in the market for a mini torque starter and came across this. Its a starter from a newer chevy. Pt#6944. I took pictures and weights.
This is the factory original starter with 2 starts on it. ahah I bought it brand new. I just realized that it wont last long with my headers.. Here we go.
Starter#1. Starter weights 20 lbs, is fargin HUGE. Bought 95 bucks. It fits 1981 and on 454s from what i heard.
Here is starter #2. As you can see, HUGE difference in weight. This fits my 454 also.
7lbs. Its a magnetic type and supposedly has more torque then the huge original one. Its about 95 bucks also.
Side by side comparison
Anyways, it now clears my headers VERY nicely and im going to make a little heat shield for it to extend the life of it also.... Just i have never seen this and figured if i could help at least one person by my post, why not....
Old 04-30-2009, 12:53 AM   #204
Riveted1
Tasty Cakes!
Riveted1's Avatar
Yeah there's a thread floating around here somewhere about those starters. Good find none the less!
Old 06-01-2009, 07:34 PM   #205
lyrikz
PITbut
lyrikz's Avatar
Havent updated in awhile.
Started puttin on some mud. Pretty thin so i just used some glaze. Few areas i used rage gold. Here are some pics of the body work. Nothing to exciting.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
Old 06-01-2009, 07:45 PM   #206
lyrikz
PITbut
lyrikz's Avatar
After gettin the body work straight. Put a coat of epoxy on everything. Going to go over the cab with some featherfill...
After i got done messing with the cab i wanted to get started on the bed again. I had it sandblasted (75 bucks) and as soon as i got it home, cleaned it up and shot some epoxy..
The last thing i had to do on the bed was add the smooth tailgate and remove and reinstall the left side inner rail... Got the smooth tailgate for very cheap. Its a nice solid piece, fits like and absolute glove.
and sold.
Old 06-01-2009, 07:49 PM   #207
lyrikz
PITbut
lyrikz's Avatar
I then went to test fit the panel
Fit very well. No gaps. I then proceeded to mark the spots i was going to spot weld it. I marked the areas, drilled the holes and then ground off the galvanized before i welded.
Started spot welding.
Before.
During
After
and sold.
Old 06-01-2009, 07:53 PM   #208
lyrikz
PITbut
lyrikz's Avatar
Before you weld the gate on, yyou want to put something on the bare metal on the inside. I hit it with a good coat of epoxy.
Gate all welded on and ready for some epoxy.
Gate all covered.
Once the gate was done i moved on to the bed rail.
I just used a drill bit and drilled out all 15 or so spot welds on the rail. wasnt to bad, just a TON of rust behind there. I ground it down, then went over it as best i could with a wire wheel. I then went over that with a cleaner and coated it all in epoxy.
and sold.
Old 06-01-2009, 07:56 PM   #209
lyrikz
PITbut
lyrikz's Avatar
Once i got it all covered i went back and welded up a few holes that i had.
I went and test fitted the rail. Marked the holes, removed the galvanizing and then started plugging the wholes. Pretty straight forward. There is some small gapping from the bed panel being a bit warped. Its under the stepside so im not worried about it at all. Also, the inside where there is some minor gapping im going to have all linexed so that should take care of any imprefections..
and sold.
Old 06-01-2009, 07:59 PM   #210
lyrikz
PITbut
lyrikz's Avatar
And finally, new rail... Wanted to get this done for along time and always put it off. Once i get the bed painted on the outside and the linex on, this thing will be READY... I cant believe it... Its like almost there...
Here are just a few misc pics from the garage.. parts that are in epoxy and just waiting there turn at some body work and to be put on the truck..
Next step is to get the fenders in some epoxy... Then once they are all ready to go, bolt em on. ANyone have any recommendations what to put between the step side fender and the bed??? I dont reallly like seeing that felt that they use. Any suggestions???
and sold.
Old 06-02-2009, 12:31 PM   #211
lyrikz
PITbut
lyrikz's Avatar
Interesting.
and sold.
Old 06-02-2009, 04:17 PM   #212
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good bro. they have a thin clear adhesive roll ( 3m i believe) that you can put on the fender lip to keep from having metal to metal contact, and it is much thinner than the felt. got some from a paint supply store locally and used it on my '56 fenders...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-02-2009, 04:33 PM   #213
lyrikz
PITbut
lyrikz's Avatar
Cool, thank you on that advice.... I have been feeling down lately.. No ones looking at my stuff... I feel its huge for me ya know.. Almost done... Ordering some paint in teh next week or so.
and sold.
Old 06-02-2009, 04:37 PM   #214
my67chevytruck
Under Construction
WE all need inspiration, I have a habit of reading and looking and not leaving comments,, you have done awesome!! wish we were at this stage on the father/son build. IIRC, it is called 3m assembly tape or something along those lines, ask you paint supplier, explain what you want to achieve...
Keep your head up Bro.....
L8r
Heath
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 04:51 PM   #215
lyrikz
PITbut
lyrikz's Avatar
L8r
Heath
Thanks man.. I dont know why im so butt hurt over it.... LOL.
and sold.
Old 06-02-2009, 05:06 PM   #216
my67chevytruck
Under Construction
wondering if i should use your last comment as a quote on my sig....
I might hit you up for some info on the starter, I read some where where the passenger straight dump ramhorn contacts the starter...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 05:10 PM   #217
lyrikz
PITbut
lyrikz's Avatar
L8r
Heath
Dropped ya a rep point. Thanks man.
and sold.
Old 06-02-2009, 05:11 PM   #218
lyrikz
PITbut
lyrikz's Avatar
ahaha, use it. ahaha
and sold.
Old 06-02-2009, 05:15 PM   #219
my67chevytruck
Under Construction
Must be KARMA....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 05:22 PM   #220
lyrikz
PITbut
lyrikz's Avatar
Must be KARMA....
I wanted to change my build name... Wonder if i can still do that..??
and sold.
Old 06-02-2009, 05:28 PM   #221
my67chevytruck
Under Construction
I was referring to the rep points, as i had left you one earlier... you can contact LIZ and have the name changed i'm sure.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 06:01 PM   #222
lyrikz
PITbut
lyrikz's Avatar
You did??? ahaha.. Cool...Thanks.
and sold.
Old 06-02-2009, 08:49 PM   #223
smbrouss70
smbrouss70's Avatar
I believe there are a lot of us that are still looking, but don't post unless we have some useful advice for the thread. From what I've seen, you've got it under control... I guess I should be more forth-coming with my "Atta-Boys"
It does look good! Hopefully it won't be too long before I am at that stage.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-02-2009, 09:40 PM   #224
allen123
It'll buff out
allen123's Avatar
lookin good!
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 06-03-2009, 12:16 AM   #225
lyrikz
PITbut
lyrikz's Avatar
I just do this stuff so you guys can get your FIX of pics ya know....
and sold.
