Old 04-26-2009, 11:06 PM   #1
Webrigs
Webrigs's Avatar
55-59 front end question
Will a 55-57 front end fit on a 58/9? I believe I had once heard that the cabs are the same...
Webrigs is offline   Reply With Quote
Old 04-26-2009, 11:45 PM   #2
GRIMSS
GRIMSS's Avatar
Re: 55-59 front end question
Yes the cabs are the same. You will need to use all of the '55-57 front clip.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-27-2009, 12:27 AM   #3
OrrieG
OrrieG's Avatar
You will need to trim the frame a little, the 58-59 frame is longer because the fenders are longer.
Old 04-27-2009, 07:30 AM   #4
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Mine was converted by the PO. He had just cut a notch out of the top of the frame ends. After the camaro clip was installed, I cut the ends off. I cut a little extra so that I could move the bumper closer to the body.
ChuckDriver is offline   Reply With Quote
Old 04-27-2009, 10:11 AM   #5
bensimmons_05
bensimmons_05's Avatar
Is the the distance from the cab to the radiator the same? or does the frame just extend out further infront of the radiator mounts to put the bumper out further. And how much longer?? I am performing this conversion so I am curious. Thanks for the info!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 04-27-2009, 10:52 AM   #6
OrrieG
OrrieG's Avatar
The distance from the firewall to radiator is the same. 58-59 fenders are longer in front of wheelwell so the bumper needs to be farther forward. Springs and front crossmember are also the same.
Old 04-27-2009, 10:56 AM   #7
bensimmons_05
Ok , thanks a bunch about how much do you have to trim off of the front?
Old 04-27-2009, 11:27 AM   #8
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i think the holes for the hood hinges are in different locations also, but you just have to drill new ones, no problem.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 04-27-2009, 12:32 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
The front is about 2.5" longer on a 589 and the hood hinges have different holes in the cab for 557 and 589 so you will have to redrill a hole. You may also have to relocate the rad support mounts. but I'm not 100% on that.
Old 04-27-2009, 03:10 PM   #10
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
ooooo so thats why my truck looks like it sticking its tongue out! (you could hide behind the bumper)
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 04-27-2009, 04:17 PM   #11
bensimmons_05
I didnt know this stuff so thanks for sharing guys!
Old 04-27-2009, 09:57 PM   #12
Webrigs
Webrigs's Avatar
Thanks a bunch for the input everyone.
Good to know I wasn't the only one wondering...
Old 04-28-2009, 03:23 PM   #13
1-ton of fun
polishing a turd
i am 99% sure the core support mounts on the frame are in the same location, the 58-9 frames are just longer in front of that. i have one of each at my house (a 55 for parts and a 59 under construction) but i have already cut the frame for the clip on the 59 frame. i just haven't welded back on the front frame horns because my jig broke in transit when i moved the truck to my house when i bought the place
