Old 04-21-2009, 09:57 PM   #1
lowhoe
converting a 85 c-10 to 6 lug
Im about to start a 85 c-10 project and i would like to convert it to a 6 lug pattern. I know a 90's model spindal bolts up, and could then run a 90's model lite duty 3/4 ton rotor which is a six lug. Just not sure if i would run into any other issues. Has anyone done this,,,or can provide any info? Ive searched and read a few simular threads but have found no clear answer. Big thanks.
lowhoe is offline   Reply With Quote
Old 04-21-2009, 10:43 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: converting a 85 c-10 to 6 lug
No need to change anything up front,... except the rotor. There are several companies that make them. Look at ECE. (Early Classic Enterprises) They use these all the time to put disc brakes on the front of the 63-70 pickups and keep them 6-lug. They take the same bearings as your five lug rotors. I think they are about $85 each.
For the rear,... I'd just swap in a 4x4 rearend, to get the 6-lug pattern.
Keith
Convert to disc brakes.
Old 04-21-2009, 10:46 PM   #3
lolife99
lolife99's Avatar
Here's my ECE rotors I just put on my '69.
Keith
Old 04-27-2009, 12:58 PM   #4
jdurant
Could you just change axels in the rear?
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 04-28-2009, 08:52 AM   #5
jdurant
anybody?
Joseph
87 Turbo Buick
87 GMC Sierra SWB
Old 04-29-2009, 02:54 AM   #6
heavychevy79
Cheyenne Super
heavychevy79's Avatar
No, I'm pretty sure a different mfg. made the 6 lug axles so the parts won't interchange.
heavychevy79 is offline   Reply With Quote
Old 04-29-2009, 07:19 PM   #7
lowhoe
looks like their 6 lug rotors only go up to 1970, and im building a 85
Old 04-29-2009, 09:08 PM   #8
SCOTI
SCOTI's Avatar
That would be because 6-lug trucks stopped in 70; 71 & later were 5-lug. Not many guys want 6-lug discs on their post 70 trucks (but the rotors still swap over). The suspension & brakes don't know what year they are.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-29-2009, 09:53 PM   #9
lowhoe
Yes thank you i am aware of when 6lugs stopped and 5 lugs started. I just wasnt sure if i could just swap rotors with 6 lug rotors made for a 70 or prior, or if maybe a company made a 6 lug rotor specifically for my 85. And my reason for wanting 6 lug is because there are 100x more wheel choices for the 6 lug pattern.
Old 04-29-2009, 10:13 PM   #10
lolife99
lolife99's Avatar
These rotors are a direct bolt on to your '85 spindles as long as your rotors are 1-1/4" thick.
Keith
Old 04-29-2009, 11:54 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
....And my reason for wanting 6 lug is because there are 100x more wheel choices for the 6 lug pattern.
I don't agree with this, but won't argue your point. I will say you should take a close look at the back space offered on the wheels you are considering. You might have to rethink your plan.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-30-2009, 07:32 PM   #12
lowhoe
its just a fact bro. i have wholesale accts with atleast 20 different wheel distributors, each carrying many different brands. i hookup friends and many guys in the truck scene at cost. And its just a fact that most of the new wheel designs that come out are made to fit 6 lug or other 5 lug patterns but not many will fit a 5x5 pattern. Yes, there are still many wheels out there for the 5x5 pattern but not near as many as for the 6 lug. And with those limited wheels to choose from, its not always easy to be different and still find a design you like. This is the same reason i converted my 99 2dr tahoe to 6lug. How many other obs trucks have you seen with this wheel? None that i know of
[IMG][/IMG]
[IMG][/IMG]
Old 04-30-2009, 11:22 PM   #13
sdavid
sdavid's Avatar
Yes. As long as it is the same axle. As in a 10bolt or 12bolt. Spline counts are different on axle shafts in 10bolt axles though. 6 lug 10bolts are 28 until you get to '88, then they switch to 30 splines. Or atleast that is how K5s are.
'81 C10 Stepside, SBC, T350, Wood Bed, and silverado options
'87 K5 402 BBC, T350, 3.73s locked up, 2.5"Lift, 33x12.50x15s
sdavid is offline   Reply With Quote
Old 05-01-2009, 08:47 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, valid point about the 6 lug wheels to fit late models. Usually you don't find a backspace that will fit our year trucks.
Regarding the wheel you posted, I like it but it looks similiar to a black Rhino wheel that I "think" will fit our truck.
So you can get killer deals on wheels..hmmm...
Articles-
"Refining Sierra"
Old 05-01-2009, 08:25 PM   #15
bagged74
its just $$$$$
bagged74's Avatar
yeah man there is like a thousand more 6 lug wheels available..i mean who cares if they fit worth a $hit? right? i mean as long as they are cheap.
bagged74 is offline   Reply With Quote
Old 05-01-2009, 10:05 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
My bad, it's not a Black Rhino I was thinking of, it's a Boss 335. It looks very similiar to the wheel you posted.
Articles-
"Refining Sierra"
Old 05-01-2009, 11:25 PM   #17
Rollinsqrbdy
Rollinsqrbdy's Avatar
I also agree with lohoe, Ive also been considering to go to 6 lug. Around here alot of the places dont even want to deal with 5 lug wheels. The only thing that holds me back is I love the 5 spoke wheels like coys, tt2's, kmc novas and many others. ahhhhh crap I think i just changed my mind and want to stick with the 5 lugs. lol
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 05-01-2009, 11:42 PM   #18
Rollinsqrbdy
yuuuuuuup uhuhhhhhh Im sticking with the 5 hole. yuuuppppp
New Mexico Member
Old 05-02-2009, 10:21 AM   #19
lowhoe
the wheel i posted up is the boss 330. Its the same design as the boss 335 except the 330 have 6 bars and the 335 has 5
Old 05-02-2009, 10:44 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah after looking closer at it I see they are the same wheel.
Articles-
"Refining Sierra"
Old 05-02-2009, 11:08 AM   #21
SCOTI
SCOTI's Avatar
..... Yes, there are still many wheels out there for the 5x5 pattern but not near as many as for the 6 lug. And with those limited wheels to choose from, its not always easy to be different and still find a design you like. This is the same reason i converted my 99 2dr tahoe to 6lug. How many other obs trucks have you seen with this wheel? None that i know of . . . . . ..... the wheel i posted up is the boss 330. Its the same design as the boss 335 except the 330 have 6 bars and the 335 has 5
So, w/so many more designs available in 6-lug, you went through the trouble of the 6-lug conversion only to install wheels that are offered by the same company, in the same style, in a 5-lug. The big difference in your 'example' of wheels that have "100x more choices" is one more lugnut & one more spoke.
The wheel choice isn't what sets your OBS Blazer apart. The overall look & the 6-lug conversion is.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-02-2009, 03:17 PM   #22
lowhoe
well im going to have to disagree with the point you attempted to make. First of all the 335 isnt offered in a 24" wheel which is the size i ran with the boss 330. And that is the first set of 3 different 6 lugs wheels that i had on the tahoe. And in my opinion the wheel choice on any ride can make or break the overall look. The fact that the majority of new wheels released are 6 lugs patterns or others besides 5x5 is just pure fact. The rest of all this is just individual opinion, and its also way off the subject of the thread.
Old 05-02-2009, 03:58 PM   #23
jdurant
I don't know if you have followed my "wheel opinions" thread. But Pyrothechnic posted this link-http://www.skulte.com/product_info.p...products_id/77
They enable you to convert from 5 lug to 6 lug. I think that is the way that I am going to convert. That way if you ever wanna go back, you can. But, of course you would loose backspacing this way. They have to be atleast 1.9" wide.
One thing that some people aren't understanding is that not all 6 lug wheels are built positively offset. Besides, you can get a 6 lug wheel custom made for the offset that you desire. Just like a 5 lug.
I feel you.
Besides, isn't doing something different what hotrodding/custom car building is all about?
Joseph
87 Turbo Buick
87 GMC Sierra SWB
Old 05-02-2009, 04:34 PM   #24
SCOTI
SCOTI's Avatar
Wheel adapters can range from 1~4". Skulte @ one point in time even made them in 7/8" (I have a set). Since it was felt the thread was getting "off subject", for an 'easy' swap to 6-lug pattern on a 73-87 you can.....
  • Use wheel adapters F/R
  • Use aftermarket 6-lug rotors on 71-87 spindles & swap in a 73-87 4x4 rear axle housing
  • Purchase custom aftermarket axles in a 6-lug pattern
  • Use 88-98 6-lug Lt.Duty 3/4 ton front brakes
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-02-2009, 04:37 PM   #25
jdurant
Moser quoted me $320 with studs.
Joseph
87 Turbo Buick
87 GMC Sierra SWB
