Old 04-30-2009, 02:18 PM   #1
chucks1967
Exclamation I need a picture of a 62 transmission cross member
my buddy and I have been looking everywhere for a reproduction cross member for a 62 c20 but have been unsuccessufl I guess unless someone on here has a better Idea we will be frabracating one. If some one would be so kinds as to post a pic of theirs so I can get and Idea of what the original looks like.
chucks1967 is offline   Reply With Quote
Old 04-30-2009, 03:24 PM   #2
slepysal
slepysal's Avatar
Re: I need a picture of a 62 transmission cross member
not oe but try this link
http://persh.org/pickup/UnderTheHood.htm#Crossmember
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-30-2009, 03:37 PM   #3
chucks1967
Originally Posted by slepysal View Post
Thanks, The link never siad exactly what year the frame/truck was. I believe 60-62 are the same but 63-66 are different. Thanks again..
Any one else can help out with some pics from 60-62 of the trans cross member I would sure appreciate it.
Old 04-30-2009, 04:11 PM   #4
slepysal
slepysal's Avatar
Yes you are correct the 60-62 frames ( torsion bar susp)Are the same 63-66 ( front coil susp) are the same The oe Trans cross member is rare, and when (if) you find one pricey
Good luck
Old 05-01-2009, 11:11 AM   #5
chucks1967
..gona bump this. I really need a good pic of an oe trans cross member. Thanks,
Old 05-01-2009, 05:02 PM   #6
slepysal
slepysal's Avatar
Man I've looked all over , cant find a pic !!! Some one has to have one
Old 05-01-2009, 05:56 PM   #7
padresag
there is a picture or illustration on one in the assy manual. I think that it may have been used only with a hydramatic application, which would have only been used in the GMC's and it fits into the x frame
what I don't know is whether or not that they used the p/glide in the chevs from 60-62 and if the did ; did they use a rear trans mount or was it bellhousing mounted? and that will answer that part of that question as if they rear mounted a cast iron p/glide then there would be a similiar crossmember
ron
if one needed a crossmember for there. it would not be difficult to fabricate , but I doubt that you would be able to buy a reay made one
padresag is offline   Reply With Quote
Old 05-01-2009, 06:26 PM   #8
slepysal
slepysal's Avatar
At one time I was bidding on one on ebay , it sold for 300.00!!
Old 05-01-2009, 06:30 PM   #9
padresag
how far did you bid?
ron
Old 05-01-2009, 07:19 PM   #10
slepysal
slepysal's Avatar
ron
I stoped at 125.00 , didnt need it. I was surprised to see it sell for so much. If I need one I'll fab one up
Old 05-01-2009, 10:08 PM   #11
hewlett2002000
hewlett2002000's Avatar
well i have a 62 frame sitting in my shop that im fixing to get rid of one way or another. nobody seems to want it. it had a powerglide in it factory so i dont know if it would be the right one, but you can have the crossmember from it if it will help you. lemme know.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 05-04-2009, 09:21 AM   #12
chucks1967
Hey hewlett, I just sent you a PM.
Old 05-11-2009, 09:31 AM   #13
chucks1967
No one.... its hard to believe there are so few 62 guys on here..
Old 05-13-2009, 03:07 PM   #14
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Cool Re: I need a picture of a 62 transmission cross member
Not much help.....but better than nothing.
Yes...... There are leaks every where!!!!!!!!.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
