Old 04-30-2009, 10:55 PM   #1
tires2burn
tires2burn's Avatar
Front cab supports are shot.
I'm the new guy here. Hope some of you can help me out. What is the best and easiest way to replace the front cab support braces? Give me some where to start. Thanks
tires2burn is offline   Reply With Quote
Old 04-30-2009, 11:07 PM   #2
tim21391
tim21391's Avatar
Re: Front cab supports are shot.
i air chisled mine off.. they are easy to replace.. just you will need to get new cab mount bolts.. because if your support is shot i bet your mount is in need of care... there is spot welds you can drill out or just be like me and air chisel them out.. it took me a good half day to do both.. then they just slide in and weld to the floor and inner rocker...
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-30-2009, 11:10 PM   #3
tim21391
tim21391's Avatar
and looking from your name it says that was your first post! so i gotta say :welcome: from salina, ks.. this is the best place ever for resources
Old 04-30-2009, 11:19 PM   #4
Normy71
Welcome from Canada
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 04-30-2009, 11:35 PM   #5
tires2burn
tires2burn's Avatar
Do I have to remove the front sheet metal to jack up the cab? Thanks for your quick response.
Old 05-01-2009, 01:04 AM   #6
Jim_PA
I didn't, but I only did the cab mounts, not the supports. I jacked up each side about 3 inches without a problem.
Jim_PA is offline   Reply With Quote
Old 05-01-2009, 10:06 AM   #7
tim21391
tim21391's Avatar
sheet metal? you talking about fenders? i didnt what jim said.. took the mounts out..stuck a 2x4 on the jack on its side.. jacked it up til the jack would go no more then went to work with air chisel... be careful if u air chisel.. i came through the floor so i put a new floor piece in around where the bolt goes through
