05-01-2009, 11:46 AM | #1 |
ac evaporator question
sorry if this has alredy been asked, i did a search... manny searches, and came up with nothing. i read someware that someone converted their factory air evaporator to a orface tube design from a newer truck, like an 87 blazer or truck. my question is how hard was this and what year and model evaporaror are you using? thanks for anny help... i just got a 69 c10 long bed and it has factory air and id like to do ths mod as i know the orface tube system like the back of my hand and can get it blowing ice out the vents
05-01-2009, 12:16 PM | #2 |
Moderator
Re: ac evaporator question
You are talking about a POA upgrade kit. It is used with the factory evaporator coil. Here is what it looks like. It will not make your A/C system blow any cooler than the original POA valve.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-01-2009, 01:30 PM | #3 |
Middle-aged Curmudgeon
I'm planning on re-making my system into a CCOT setup when I get the air going. Mosesburb figured out the parts to use in his excellent build thread.
Evaporator number is an ACDelco 15-6249. Long GM number is 3035171. It fits '77 Montes, Chevelles and Impalas. According to mosesburb it lays right in there but is a row or two shorter, so you'll have to fab a small bracket to weatherstrip it properly. Accumulator number is ACDelco 15-1648. Fits many late '80s & early '90s mid-sized sedans. Question back to you-- what are you planning to use for a condenser? The factory one or a different shape/style?
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
05-01-2009, 06:38 PM | #4 |
i was thinking of using like a 95ish 1500 truck condencer because it is all reddy for 134
05-01-2009, 06:55 PM | #5 |
member #16
Heres a link to the orifice upgrade kit. http://www.oldairproducts.com/catalo...00_407_4071972
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 05-01-2009 at 06:56 PM. |
05-01-2009, 07:01 PM | #6 |
ok guys ... lets get this strait... i dont want to upgrade the old poa valve... i want to convert to a orface tube evaporator.
05-01-2009, 07:24 PM | #7 |
Not sure what you're getting at . . . why would you keep the POA valve and install an orifice tube friendly evap?
05-02-2009, 01:45 PM | #8 |
I don't want to keep the poa valve ... I want to convert the whole system to a orface tube system
05-02-2009, 02:12 PM | #9 |
Okay, then the two part numbers I posted earlier will work. Surf over to mosesburb's build thread and look at the first picture in post #7. You can even see the orifice tube dimples on the inlet of that evap. The accumulator will screw right onto the outlet.
