Old 05-01-2009, 01:55 PM   #1
powerbench
powerbench's Avatar
Cross member measurements
Does anyone have the crossmember and inner frame support measurements....or a box off there truck to go measure some thing for me? I'm doing a leaf to coil swap and thought there would be , at least a few bolt hole that would line up , but no such luck....and the manual is a bit deceiving in it's measurements. Thanks
powerbench is offline   Reply With Quote
Old 05-01-2009, 02:31 PM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: Cross member measurements
The holes for the trailing arms are already there
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-01-2009, 03:08 PM   #3
powerbench
powerbench's Avatar
the trailing arm holes are there, but not for the coil saddles or the cross member that holds the shocks , or the inner braces for the frame just in front of the shock cross member....damm i wish i still had that parts truck, i took some pics , but had to do it with the bed on ....and now they don't look as usfull as i though...
Old 05-01-2009, 03:45 PM   #4
jbristo67
jbristo67's Avatar
I can get you some pictures on monday make me a list of what you want to see
2011 Nissan Armada
Old 05-01-2009, 03:49 PM   #5
powerbench
powerbench's Avatar
k will do .....i 'm hoping that somebody else will see this today to ....don't make a special trip though....if i have to i could get it this weekend if i make it to a wrecker
Old 05-01-2009, 04:25 PM   #6
jbristo67
jbristo67's Avatar
I am going to go over there monday any way I have to take this guy a qjet and get some stuff from him
2011 Nissan Armada
Old 05-03-2009, 11:43 PM   #7
powerbench
powerbench's Avatar
hey 67 i'am looking for the measurement from the edge of the back cross member to the center of the shock cross member...and anything that ya can locate the inner portion of the frame supports..Name:  frame smaller 2.jpg
Old 05-04-2009, 09:10 AM   #8
Bullseye54
Powerbench I'm finishing the same swap with my 68' short bed.It's 42" from the end of the frame rail to the center of the cross member. When I was done I realized there is an oblong hole in the side of the rail that was dead center of the cross member.Everything came out good alignment wise on mine.I'm over removing rivets though.
1967 C20 Custom - 396/TH400
1968 GMC short step-350/M21
Bullseye54 is offline   Reply With Quote
Old 05-05-2009, 02:26 PM   #9
powerbench
powerbench's Avatar
Thank you sir,i'll go out and see if this works when it stop raining around here..
