Old 05-02-2009, 06:37 PM   #1
Pont406
Short trip in my 69 c10.
My cousin is moving back home with her parents. It was a while since I had my truck on the freeway. I stoped using freeway because I need to redo a front end. Front suspension has a lot of play. So this morning I drove to South Pasadena and load the truck. I am running a 4 row radiator with a late model firebird dual fan set up. Around town it runs at 170 degrees. It was overheating a little at 200 degrees due to 3500 cruising rpm. Truck actually handled and stop better when it was loaded. I need to do some sound insulation inside the cab. Anything from 3500-4000 rpm and it's hard to keep a conversation going. Nothing broke during the trip but th400 sprayed oil all over the place. I will need to see why. I already got a biggest summit alum radiator and trans cooler on oder.
Pont406 is offline   Reply With Quote
Old 05-02-2009, 06:57 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Short trip in my 69 c10.
200 degrees isn't hot really. The stock thermostat doesn't even open until 195 and those gauges aren't always perfectly accurate.
3500-4000 cruise RPM is way too high if you're going to do a lot of cruising. How far away does your cuz live?
Rents up there are pretty crazy,bet she saves a bundle living at home.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-02-2009, 07:01 PM   #3
gintaras
I wonder how long it will take before someone request pics of said cousin
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 05-02-2009, 07:07 PM   #4
Boog
laying low
Boog's Avatar
Looks like you just did....
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-02-2009, 07:58 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
In conjunction with the earlier comment....
Member Nr. 2770
Old 05-02-2009, 09:31 PM   #6
big mike71
big mike71's Avatar
If you use distilled water instead of regular water it will lower the temp 10 to 15 degrees
big mike71 is offline   Reply With Quote
Old 05-04-2009, 10:17 AM   #7
6772owner
Gearhead
6772owner's Avatar
The high RPM's have anything to do with the high temp?
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 05-04-2009, 10:20 AM   #8
Sinister
Between Trucks...
Sinister's Avatar
Have any picture of the fan setup? Might be blocking airflow through the radiator at speed. My cruise rpm is high as well, 3100-3300 rpm. Runs 190 degrees with a nylon flex fan and 3 row radiator on my 350.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
