Old 05-02-2009, 11:00 PM   #1
Alex Hayley
suspension drop and a-arm bumpers
Can anyone speak from experience about a 2" drop and the a-arm(upper and lower) bumpers? Do the originals work just fine or do they need to be shaved?
Alex Hayley is offline   Reply With Quote
Old 05-02-2009, 11:12 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: suspension drop and a-arm bumpers
I will have to let someone else answer this one, but I believe that with a 2" drop you will be find with the factory bumpstops.
I'm going to get this moved over to the suspension section for you as well, hopefully a few more responses for you over there.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-03-2009, 12:16 AM   #3
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Moving this for you.
oldiron is offline   Reply With Quote
Old 05-03-2009, 06:09 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The upper A arm bumpers don't matter on the drop. They are there to keep the suspension from overextending when unloaded.
On the lower bumpers, you will be fine with a 2 inch drop. After driving it a few weeks, you might look at the bottom of the crossmember where the lower bump stops hit it. If you see a shiny spot in the grime, you can know that the snuber has been hitting it, and you can trim accordingly if needed.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-08-2009, 07:19 AM   #5
DZL1
One day.....
DZL1's Avatar
TX couldn't of said it better.
DZL1.
DZL1 is offline   Reply With Quote
