Old 05-05-2009, 01:43 PM   #1
rafterman191
Which bolt is it? TH350
I have 2 similar bolts. Same thread size, same metric head, but 1 is slightly longer. 1 goes into the speedo gear housing at the rear drivers side and 1 holds the cable linkage that runs into the shift kit through the passenger side of the tranny. I think I used a 10mm if that helps. Which one is which? Thanks.
rafterman191 is offline   Reply With Quote
Old 05-05-2009, 03:09 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Which bolt is it? TH350
My guess would be the longer one to the detent cable and the shorter one to the speedo gear.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-05-2009, 04:13 PM   #3
rafterman191
I had the shorty in the detent cable and was getting fluid dripping out. There's not a little rubber seal or similar for that connection is there? I never saw one when removing the old tranny, but it was kinda hectic.
Old 05-05-2009, 05:02 PM   #4
rafterman191
Poo, I swapped em and it did not help. I Wonder if the little plastic piece is cracked or something.
Old 05-06-2009, 09:55 AM   #5
jchav62
1962 C-10
jchav62's Avatar
It may be cracked. I've had that problem before. I can't remember if it takes a seal or an o-ring. I imagine it would. Your best bet would be to get a new one and replace it. Good luck..
Joseph Chavez
Old 05-06-2009, 10:29 AM   #6
rafterman191
Thanks. I found a few pics and it does have a little rubber o-ring that must have been lost during the swap. I am going to try to find a suitable replacement at Lowe's before I spend the $20 replacing the whole thing. Well at least I know now, that is really the frustrating thing is not being sure.
Old 05-06-2009, 11:34 AM   #7
jchav62
1962 C-10
jchav62's Avatar
Cool! The camera is our friend.
Joseph Chavez
