Old 05-06-2009, 09:35 PM   #1
Mike Massingill
Electrical Issue
Just finished rewiring truck, new single wire alternator with built in regulator, new optima battery.
We have a main circuit 30A fuse that blows after driving the truck about 5 minutes. Replace the fuse and drive another 5 minutes. Does not blow while the truck is idling.
We do not feel we have a short, we have traced the wires and the wiring is new.
We feel the fuse is blowing from an overload of maybe 35-40A.
Could this be caused by the atlernator somehow over feeding the circuit?
I will pull the wire to the alt in the AM and drive it to see what it does. If it does not blow what do you recomend to fix it?
Thanks, Mike
Mike Massingill is offline   Reply With Quote
Old 05-07-2009, 12:50 AM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Electrical Issue
You would need a 80- 100 amp fuse. Best way use at least 8 gauge wire with a fusible link where it connects to bat.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 05-07-2009, 09:09 AM   #3
Mike Massingill
Yep, I think that is the problem.
I will change it out today.
Old 05-07-2009, 09:23 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Before you install a higher fuse check the output voltage. The one wire alternator shouldn't overfeed the circuit it should self regulate to within 13.8 to 14 vdc (+/-). Put a meter between the battery posts see what voltages are being fed to the battery at idle and at higher rpms.
More than likely it's the alternator. From what I've read about single wire alternator, it needs a "feed" to excite it to start regulating and usually gets it from the stators themselves after you crank it. Yours doesn't blow the fuse at lower speeds because it's using battery power at that point. Once you rev it up to higher speeds the transistor gets "excited" and regulates the output.
68gmsee is offline   Reply With Quote
