Old 05-10-2009, 01:40 PM   #1
ihatericeburners
ihatericeburners's Avatar
A/C evacuation and charge ?s
So... I am want to evac my new a/c system on my truck with a non-automotive evac pump thats used on homes. I have the hoses. Can i do this?
Sould I?
PLEASE HELp! Tanks!
ihatericeburners is offline   Reply With Quote
Old 05-10-2009, 02:27 PM   #2
ihatericeburners
Re: A/C evacuation and charge ?s
What i want to do is use the quick connect for charging a system, that comes in the kit from Autozone, and hook it up to the manifold and pump it down.
Suggestions please
Old 05-10-2009, 02:40 PM   #3
truckdude239
truckdude239's Avatar
do u have freon in the system right now? i would say no because any left over r-22 in that system mixxed with r-134a would wreckt he system. if your just pulling a vaccuum it shouldn;t be a problem, most shops do not charge much to remove freon from cars and trucks
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-10-2009, 03:29 PM   #4
Zeke
Active Member
Not a problem, if anything it will just pull a vacuum faster. My neighbor is in the HVAC business and I borrow his pump all the time, but you really should pull the vacuum and charge the system thru a set of manifold gages.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 05-11-2009, 10:06 AM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Did you replace any parts other than the r-12 to 134a quick connect?The oil should at least be replaced and the filter dryer.Any good vac pump will work to evac sys.
sneakysnake is offline   Reply With Quote
Old 05-11-2009, 12:57 PM   #6
ihatericeburners
My system is new, NO freon.
My dad is out of the home HVAC bussines for a while now. He thinks he can do it i just dont want to trust my $1500, brand new system to him without testing some waters first.
We have a manifold but the problem is that his hoses are different. They are not compatible to the pump.
Old 05-11-2009, 02:52 PM   #7
big_al_71
big_al_71's Avatar
You are in florida do a road trip to Miami and I will have it done for you as we have the Robinair machine here in the shop....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
