05-12-2009, 03:56 AM | #1 |
Brake Booster?
I got a big trip out to Pismo Beach coming up. The atrocity that are my front drum brakes are being addressed.
I want to buy a new brake booster. Since I am going to disc from 71-72 should I get the larger 10 3/4 brake booster or stay with the original 8 3/4. And will the bigger 71-72 boster fit the bracket, and the master cylinder? Thanks |
05-12-2009, 10:24 PM | #2 |
Re: Brake Booster?
well gee Dtech I think you should use the 10 3/4 booster to accomodate the disc brakes. But I don;t know it will fit the 8 3/4 brake booster brackets and MS on your 69. Maybe some one else knows the answer to this question????
LOL |
05-13-2009, 05:19 AM | #3 |
Re: Brake Booster?
The larger booster will fit if it is off of the C-20 trucks. Here is a picture of the C-20 truck booster mounted in a 71 C-10.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 07-14-2009 at 12:52 PM. |
05-27-2009, 09:09 PM | #4 |
Re: Brake Booster?
Nice, just wondering if there are any special needs to change my master cylinder set up to a power brake booster, brackets, lines, or is it a simple fit?
What years will fit? Thanks |
05-27-2009, 09:58 PM | #5 |
Grandpa in the rustmobile...
Re: Brake Booster?
i changed from manual drum to power drum using a booster from a 72 gmc
bolted right onto my firewall, i added a vacum line for the 'power' part, and used the brake pedel rod from the 72 also, and had to adjust the brake pedel light sensor thing, its a pita but can be done with patience and time lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
