05-13-2009, 12:13 PM | #1 |
Why does it taste purple?
URGENT HELP needed.....tail light problem
I need help with this asap as I am taking this truck on a weekend long cruise trip. I have no tail lights but my brake lights and turn signals work perfectly. I am stumped on this and have no time to completely re-wire the rear end of this thing by tomorrow morning. I am on a lunch break as I type this plea for help. I am sure this is not a ground issue due to the rest of the lights working condition. Help a brother out
Hello, my name is John and I'm a truckaholic |
05-13-2009, 12:18 PM | #2 |
Registerd User
Re: URGENT HELP needed.....tail light problem
Do you have front park lights? Give them the wiggle test.
05-13-2009, 12:30 PM | #3 |
Rods
Do you have dash lights?
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
05-13-2009, 12:41 PM | #4 |
1962 C-10
Have you checked the bulbs?
One time on my buddy's '60, the tail lights weren't working, with the lights on, we shook and wiggled the tailgate and magically they came back on.... I believe it was a ground issue that the vibration from shaking the tailgate fixed.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
05-13-2009, 12:59 PM | #5 |
yeah, more info needed?
have you checked for voltage at the rear lights? have you checked fuses? do you have a license plate light? as you probably know the brake/turn is one circuit and the taillights are another.....
CHEVY ONLY |
05-13-2009, 01:09 PM | #6 |
ok sorry.yes i have front parking lights. I dont have dash lights and no tag lights. I have 12 volts across all fuses and the bulbs are brand new. No voltage at the rear lights until I hit the brakes
05-13-2009, 01:12 PM | #7 |
Rods
dash lights a common to tell you there is no power to the rear of the truck (incomplete circut).
05-13-2009, 01:26 PM | #8 |
the dash and the dome are the same circuit, the dash lights are not on the circuit with the taillights. also the taillights and the front park lights are on a separate circuit I think, if it is the same as the 64-65, not sure if there was a change in 66 check for power at the headlight switch, the '64 diagram show a brown wire there. if you have power there, then check the firewall connector, if there is power there, then check the connector under the rear of the bed.... if you have no power at the switch, then I would suspect the switch itself.
CHEVY ONLY Last edited by joe231; 05-13-2009 at 01:29 PM. |
05-13-2009, 02:30 PM | #9 |
So I take it that the tail lamps are grounded at the bezel?
05-13-2009, 02:37 PM | #10 |
Rods
YES. BUT IF IT WERE A GROUND THEN YOU WOULD HAVE ALTERNATING FLASHING OR DIM FLASHING WHE YOU USE YOUR BLINKER. ALS DIM BRAKE LIGHTS WHEN YOU HVE NO GROUND.. i WOULD START AT YOUR DASH SWITCH.. THATS COMMON
05-13-2009, 03:33 PM | #11 | |
yes the the tail lights ground through the socket/bucket....but as stated it should be grounded ok if your brake and turn works, unless they are very dim..
CHEVY ONLY |
05-13-2009, 03:35 PM | #12 |
Rods
sorry I am in a service dpt. they like everything to be in caps
05-13-2009, 03:36 PM | #13 |
CHEVY ONLY |
05-13-2009, 03:41 PM | #14 |
Rods
lol if you look I did push shift for the (i)
05-13-2009, 03:42 PM | #15 |
I see that now
CHEVY ONLY |
05-13-2009, 07:07 PM | #16 |
Broken wire. Re-wired the rear and good as gold. Thanks guys
05-13-2009, 07:12 PM | #17 |
I know this is off topic but how about some pics of that bad boy?
05-13-2009, 07:32 PM | #18 |
right on, glad to hear it
CHEVY ONLY |
05-13-2009, 08:24 PM | #19 | |
Page 1 and 2 have some older pics. I will more than likely take some newer pics this weekend http://s12.photobucket.com/albums/a224/05xd/
