Old 05-17-2009, 10:30 PM   #1
rhodog77
rhodog77's Avatar
How to remove cab corner glass.......help
Can anyone give me a tip on how to SAFELY remove the cab corner glass on a 5 window. thanks for any input.
rhodog77 is offline   Reply With Quote
Old 05-17-2009, 11:07 PM   #2
sgtusmc
sgtusmc's Avatar
Re: How to remove cab corner glass.......help
I used a razor blade and my wife. She stayed inside the cab, while I used a razor blade and cut the rubber. Once it was half way cut she kinda pushed a little and out it came. Work slow and lay a blanket on the ground in case you drop the glass. Oh, you half to remove the plastic rubber lock (the black or chrome locking strip on the outside of the rubber window seal). It's easy to take out...a little harder to put back in.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 05-17-2009, 11:27 PM   #3
Dads 68 GMC
Dads 68 GMC's Avatar
the wife on the inside is good,you should not use a razor blade unless your rubber is bad. use glass cleaner or soapy water especially going back together
Dads 68 GMC is offline   Reply With Quote
