05-18-2009, 12:58 PM | #1126 |
One day...
Re: My 1965 build thread
We have a rooster from hell out at mom and dads he has 3" spurs, youd be the man if you could catch him and put socks on him! He fights back |
05-18-2009, 01:15 PM | #1127 | |
Shloooooong bed member #2
Alan you have no one to blame but yourself on this jacking if it takes off "Sexier than socks on a rooster" That's just too funny there.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
05-18-2009, 01:26 PM | #1128 |
Rods
Hate to say it but if the clear is fresh you could sand it blend the color back then reclear.. That spot in ther rear may be hard to see when blended.
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
05-18-2009, 02:33 PM | #1129 |
One day...
Have you figured out the run situation yet Alan? You going to take a lot of tedious wet sanding and try and not go through or sand it down and re clear?
05-18-2009, 02:39 PM | #1130 |
I'm just glad to be here!
Man, Allan, the more I read your thread the more impressed I am with your skills. Your painting is outstanding. I had a run similar to yours in a door, luckily, I could use a block to sand it our and keep it level. That one is in a tricky spot since the panel is concaved. I know that you will make it right!
Really digging your colors. You have insired me to work on mine again and to get my shop started. I think I asked before, but what size is your home shop?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-18-2009, 03:27 PM | #1131 | |||||
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
05-18-2009, 04:14 PM | #1132 |
Rods
I see yours at 30x30 and mine seems so small at 25x30
05-18-2009, 08:24 PM | #1133 |
Daring to be Different
Allan, I've been gone since Friday. Man your getting some work done. It's coming out really good. I like the color combo even more now, Fish Eyes, and runs suck. Don't they have a tool to shave off runs? Then color sand them out.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 05-18-2009 at 08:24 PM. |
05-18-2009, 11:38 PM | #1134 | |
No matter how big your work area is it will never be big enough.
Ok here is the process I went thru in sanding out a run. It took me about an hour taking my time. In that amount of time I could have sanded and recleared. Then there is the materials cost. I've still got 3 more to work out. What would really suck is sand thru on the last one. With this process it can still happen, but not as much. This is what I used. there are other products that can be used. Apply it sparingly. It takes along time to sand it off. This a small block I cut from a large paint stir stick. I used 1000 grit and went over it with 2000 prior to buffing. Sanding progress Mini air powered buffer Buffed but still needs a little more.
Alan
05-18-2009, 11:51 PM | #1135 |
Resistance is Futile
I had a container of that in my hand after our pm's. I think the glaze is what I really need to use. Thats a good use for it cutting those runs down.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-19-2009, 05:44 AM | #1136 |
Hey Y'all!!
Great work Alan. It's little tricks like these that help edjumacate us all on paint/body. Keep it up!
Just hopin' I live long enough to finish something!!! |
05-19-2009, 07:25 AM | #1137 |
keep it up!! I saw a trick on tv to use a razor blade perpendicular to the surface and scrape the run down then you can sand to smooth it out, then buff.... any thoughts?
CHEVY ONLY Last edited by joe231; 05-19-2009 at 07:27 AM. |
05-19-2009, 08:01 AM | #1139 | |
CHEVY ONLY |
05-19-2009, 08:11 AM | #1140 |
Rods
i just used this method on my bike tank. works but still have to sand
05-19-2009, 10:46 AM | #1141 |
Allan, that's a slick trick. Thanks for sharing.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
05-19-2009, 11:39 AM | #1142 | |||
Hey ya'll, how 'bout some rep points for that one. Yes I'm begging. Out of about 300 views a day on average one person gave out rep points for that tip.
Alan
05-19-2009, 01:10 PM | #1143 |
One day...
It was me i think because it wont let me give you any more points
05-19-2009, 01:11 PM | #1144 |
One day...
Mine is similar to it but not exactly, thats probably to hold the razor.. mine isnt that fancy the blade just snaps in
05-19-2009, 01:26 PM | #1145 |
Member of the longbed union.
Joe I saw that tip done on power block, not sure which show it was, but looked usefull. I think Alans would be a lot better for the novice like we all are. Keep up the tips and tricks Alan
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
05-19-2009, 01:28 PM | #1146 |
I try to get you as much rep points as I can Alan but it says I have to spread some around before I can give you some more. Who wants some!
05-19-2009, 02:07 PM | #1147 |
What the hell is a Rep Point??
05-19-2009, 04:33 PM | #1148 | |
I try to give them out regularly, but sometimes I forget Dennis, Look here REP POINT LINKY
CHEVY ONLY |
05-19-2009, 06:24 PM | #1149 | |||
Alan
05-19-2009, 06:54 PM | #1150 |
Alan,
I know what your saying about the rep points...but we can only spread so many during the 24 hours or only so many on a thread... So, take it from someone who can't wait for your updates on your rig and I hope I'm not speaking for myself but I enjoy and learn so much from your post. rep points or not...... So it's not the rep points, it's the veiws to your thread you should be aware of. over 53,000, that's way more than Joe and his steak... I meen we are all still waiting on the update on the cabinets.... Thanks Alan
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q Last edited by 4dranch; 05-19-2009 at 06:58 PM. |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
