Old 05-18-2009, 07:02 PM   #1
70 net440
Junior Member
70 net440's Avatar
63 C-10 TH 350 install?
Which length output shaft TH 350 is closest to a 3 speed manual in length? Do you need to add a cross member for the trans mount or can something be welded onto the park brake crossmember? I assume I'll have to remove the bellhousing mounts from the frame. Thanks for any replies.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 05-18-2009, 08:30 PM   #2
70 net440
Junior Member
70 net440's Avatar
Re: 63 C-10 TH 350 install?
ttt
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 05-18-2009, 11:58 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I believe you would remove the bellhousing mounts. Both my trucks were originally floor shift standards and that stuff was long gone by the time I got them. I dont know what length trans would be close to the standard trans. I would beef up that support if using it for a trans mount...my pickup had it done that way by the PO and I ditched it. Plenty of reasonably priced trans crossmembers out there IMO.
Are the output splines the same for standard and auto? I would figure the driveshaft would have to be re-done anyway.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-19-2009, 03:26 PM   #4
buster0104
I don't know if this will help but I used a short tail shaft TH350 and did not have to cut my driveshaft. I don't remember anything else about it, it was about 10 years ago or more.
buster0104 is offline   Reply With Quote
Old 05-19-2009, 08:38 PM   #5
70 net440
Junior Member
70 net440's Avatar
Thanks, I have a cross member from a later model truck. I'd like to stick with the stock e-brake setup, but I'm not sure there is enough room for both. I'll have to measure a case to see were the mount lines up. Does anyone make pre-bent cooler lines for a TH-350/downflow radiator combo?
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 05-20-2009, 09:47 AM   #6
MacAttack
283 Drama Queen
MacAttack's Avatar
Original Parts Group (in Seal Beach, CA) does, but I would advise against it. Just went through that and while the lines are bent correctly - the fittings going to the radiator are incorrect. I had to cut them off and plumb with rubber hose.
Not worth it. Wouldn't do it again.
Better to buy a tube bender and some brake tubes and do it yourself - IMO.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 05-20-2009, 10:05 PM   #7
70 net440
Junior Member
70 net440's Avatar
What was wrong on the fittings for the radiator? Could the fittings in the radiator be changed?
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 05-23-2009, 07:30 AM   #8
70 net440
Junior Member
70 net440's Avatar
Has anyone reused the 3sp. column shift column to shift the automatic? I thought I saw someone do this before.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
