Is a 2003 Yukon XL a good rig?
Looked a a 2003 Yukon xl today and was wondering if anyone has or had one and if the model had any type of common issues/problems? Any info would be appreciated.
Thanks, Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Catchy title goes here..
![]() Join Date: Mar 2002
Re: Is a 2003 Yukon XL a good rig?
redneck girl n i both do. imho they are damn good vehicles. Josh could fill you in on the normal issues.
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
I love ours, They have a few issues but mostly were worked out under warranty. The factory equipped a/c compressors tended to grenade internally but usually under 30k miles on them. Ours has 82k on it, we bought it at 58k and have done nothing but oil changes and a rear window motor that were out of pocket expenses. I replaced the cluster under GM special policy warranty when the speedometer stopped working. It needs an intermediate steering shaft but I just lube it every other oil change. Overall they're good trucks with very little to worry about and are a real bargain as cheap as they have become in the past year.
Josh
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com 6772chevycom@gmail.com |
Thanks for the good info. I have found a very, very clean, loaded 2003 with 110K miles and its a 4x4 to boot. It doesn't look much bigger than my grand Cherokee when you are looking out the front windshield but when you look back, its a long way to the back of the vehicle.
I need to get a carfax on it, not sure its the "one" yet but for what they are asking and its condition has me thinking pretty hard. Thanks again!
Low & Fast!
I have just a Yukon, but I tow with it all the time, we love it!
Good rig but the 2003 is a one off electrical system. The wiring for a brake controller requires a new pig tail available from the dealer to solve a trailer brake activation problem. 2004 fixed that problem. The gauge cluster issue is common, as is the 4whl drive switch going out and the fuel pump.
I have an 03 Z71 Suburban and like it but I wish I had waited for an 05. 110,000 miles is alot for one of these rigs. Things will go wrong on it. I would buy a new one with lower miles. |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
My wife has a 02 with 109,000 on it now, The only thing I have had to do to it is replace the rear e-brake shoes. Other than that, just normal maint. When I was at the dealer i saw them regularly with 200k plus and still running great.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
