Old 05-20-2009, 05:59 PM   #126
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project Slo-Go 67
Originally Posted by allen123 View Post
awesome build!
Thanks Allen, my 16 yo Son is stoked, our HS does not have autobody but he can take it if he wanted to go to a neighboring city's HS, We both thought it would be more Fun doing a Father son build.
Keep up the good work on your Truck..
Heath
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-20-2009, 07:07 PM   #127
mahanian
C10 addict
mahanian's Avatar
Originally Posted by my67chevytruck View Post
Mahanian,
We just removed the rear springs and trailing arms when we removed the rear end, because i was going to scrap the lwb frame, so we removed all parts and left a bare frame . you can order replacement axles to make the '67 a 5-lug, but since we had the '72 rear end we installed it as well. we did the entire front swap, because the 72 was complete, and with the engine out of the '67 we were able to remove 14 bolts on both of them and roll the front xmember out from under it. We then tore down the '72 front suspension for paint, and rebuilt the suspension. I ordered '72 2 1/2 drop spindles from ECE, along with 4' drop springs for the back.
Good luck with your build. if you have any questions, let me know and i will do my best to help you out.
Thanks for the comments.
Heath
Thanks for the info! I will keep a close eye on your build, great job so far!
mahanian is offline   Reply With Quote
Old 05-20-2009, 08:30 PM   #128
04 orange
04 orange's Avatar
Charcoal Grey would look good, was thinking about that for mine. But im going to go with hugger orange. You need to check that new drark gray on the new camaro, theres one around town, it looks awsome.
04 orange is offline   Reply With Quote
Old 05-21-2009, 09:42 AM   #129
my67chevytruck
Under Construction
Thanks, I have not seen it but will definitely check out the dark grey.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-21-2009, 04:01 PM   #130
allen123
It'll buff out
allen123's Avatar
Heath
Thanks man
Yeah you have a really nice build thats cool that your doing it with your son too, My build is kinda just me now though since vo tech but since it just got out me and my dad might start doing motor work this summer
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 06-02-2009, 10:19 AM   #131
68SWBChevy
Livin the good life!!!
68SWBChevy's Avatar
Great job on the build. Gives me a little hope and inspiration as I continue to work on mine. I haven't had any experience with rust repair either but am doing like you did and learn as I go. I think my problem is I need a better welder. I have a Clarke Mig with an argon tank but it pulsates instead of feeding the wire smoothly so the welds look like hell. Could be because I am using too small of a gauge extension cord too. Who knows. Just another reason to spend money on a new welder
James
Current Project 68 SWB factory A\C cab
Daily Driver 2004 Chevy 2500 HD Crew Cab 4x4 6 inch lift
Proud owner of a 1932 Ford Roadster "Zppn By"
http://67-72chevytrucks.com/vboard/c...pic57166_1.gif
68SWBChevy is offline   Reply With Quote
Old 06-02-2009, 10:24 AM   #132
my67chevytruck
Under Construction
Thanks for the comments! you might want to check the tensioner that holds the wire spool on (could be too tight), and the tension roller that feeds the wire through the gun.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 10:27 AM   #133
68SWBChevy
68SWBChevy's Avatar
You know that is a good thought. I will do that I haven't even thought about looking at that.
James
Old 06-02-2009, 11:58 AM   #134
gcburdic
Restoration Virgin!
gcburdic's Avatar
Come on Heath!....we need some pics!!!....Glad things are rollin' along well for you guys....I know I appreciated my brother and Dad's help throughout my project....that's all we talk about now!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-02-2009, 03:31 PM   #135
my67chevytruck
Under Construction
Geoff, ok , ok , nothing really picture worthy but here ya go , we have put a couple of coats of por-15 high heat factory grey on the ramhorns, and a lil touch up welding on the cab....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 04:16 PM   #136
culp7
HickTown
culp7's Avatar
Did you put that por-15 directly over the rusty manifold?
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 06-02-2009, 04:42 PM   #137
my67chevytruck
Under Construction
NO, they were wirewheeled, then i let them sit in vinegar for a couple of days (thanks for the tip CDOWNS) , cleaned em with wax and grease remover, then painted with the por-15 manifold grey high heat ..
the manifolds only have 2 light coats, I will probably put atleast one more heavier coats, maybe 2.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-02-2009, 06:47 PM   #138
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
I would spray it in the inside too, if you have them jet hot coated they spray the inside and out ...
72 SHORTBED 7.0 is offline   Reply With Quote
Old 06-02-2009, 09:54 PM   #139
gcburdic
Restoration Virgin!
gcburdic's Avatar
ahhhhh...pics...thanks for the fix!!!....looks good Heath....keep up the progress....and pictures....MUST have pictures....LOL
so what does the vinegar do?? (did I miss reading that post???)
Geoff with a G
Old 06-03-2009, 06:46 AM   #140
msgross
msgross's Avatar
it made ramhorn pickles!!!
they look pretty good, I have to clean mine up AGAIN since they are rusting AGAIN. I'm gonna use the hot jet stuff from www.nomorerust.com
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-03-2009, 08:53 AM   #141
my67chevytruck
Under Construction
The vinegar cleans them up real good, you can get 2 gallons at sams for around 3 bucks. I bought 4 gallons and soaked em... they came out pretty....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-03-2009, 08:57 AM   #142
gcburdic
Restoration Virgin!
gcburdic's Avatar
Cool!!!.....I know someone that needs to clean up his headers....I'll send him this thread.....
Now I hope when you fire this up soon that it doesn't smell like PICKLES!!!!LOL (good one msgross)
Geoff with a G
Old 06-03-2009, 08:58 AM   #143
my67chevytruck
Under Construction
Mike,
I may give that a try on the headers of my '56, they have been jet coated (ordered that way from summit) but seem to be fading already.. let me know how yours turn out.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-04-2009, 07:30 AM   #144
my67chevytruck
Under Construction
some pics of the touch up welding we have been working on .
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-04-2009, 08:04 AM   #145
gcburdic
Restoration Virgin!
gcburdic's Avatar
Nice touch...I saw that you were doing this over on Bruce88's build....it's "seams" to be a great idea...LOL....I made a funny!!!haha
Geoff with a G
Old 06-04-2009, 08:27 AM   #146
my67chevytruck
Under Construction
HAHA Geoff "SEAMS" to be.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-04-2009, 11:06 AM   #147
Slick67
Sofa King Crazy!!
Slick67's Avatar
Those manifolds came out great. You said POR15 first then painted?
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 06-04-2009, 12:05 PM   #148
my67chevytruck
Under Construction
Thanks, they still need another coat or two. I used a foam brush, it is a self leveling high temp paint from por -15 see the link below.
http://www.por15.com/FACTORY-MANIFOL...ductinfo/FMGG/
I wirebrushed the manifolds, let them sit in vinegar a couple of days, dried em off. and hung them up to dry internally a couple of days. cleaned them with wax and grease remover, the painted with the por-15 high temp paint. Ledzepp used the high temp paint and has had good results, so here we are.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-04-2009, 12:09 PM   #149
my67chevytruck
Under Construction
MMMMM... Fried Pickles.... Must be lunch time!!!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-09-2009, 01:43 PM   #150
Slick67
Sofa King Crazy!!
Slick67's Avatar
LUNCH!!!!!!!!!!
