Headlights don't work!
I have a 68 Chevy C-10 that both headlights arn't working, but the parking lights and the taillights are lighting up. I have not checked the bulbs, but just have a feeling that there is more to the problem since neither headlight is coming on. Are they on a separate breaker/fuse, or maybe on a seperate circuit. Any help you all can give me would be appreciated.
Redefining LowBudget
Re: Headlights don't work!
check for power at the floor high low switch and work your way backwards tot he switch.....I just fixed a headlight problem with a new high/low switch for $10
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Moving this over to the pickup forum from the suburban forum. Maybe you will get more input.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
The Red Menace
Follow this recent thread from when mine were out:
http://67-72chevytrucks.com/vboard/s....php?p=3309966
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
Second on the dimmer switch. If it goes out you will not have lights.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
You can lift the floor mat up and take a test light to check the dimmer switch with a test light use it to make sure you are getting power in with the light switch on and then check one side and the other.
I've found that the stock plugs on the back of the headlights don't like high powered halogens nor do the dimmer switches. |
