05-21-2009, 11:06 PM | #51 |
"something witty here"
Re: 71 4x4 BBC Swap: Doing what I should have done the first time!
Thats sweet, did you revise it or is it a new product? Just curious I really like it.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
05-21-2009, 11:09 PM | #52 |
I built it
yea that is a really good idea. did you do the modifcations or get it like that?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
05-21-2009, 11:22 PM | #53 |
Grease Monkey
its a revision by DIY4x
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
05-26-2009, 11:51 PM | #54 |
will that cross member fit into a 2wd frame im gonna be doin 4wd conversion on my 72
05-27-2009, 08:11 AM | #55 |
Grease Monkey
Yes, I've seen some 2wd trucks on this forum use it. The only thing that I have found. Is that with this crossmember either the pan or crossmember bar requires to modifications to fit. My oil pan hits the center bar. So I am going to be building a new center center bar.
05-27-2009, 06:10 PM | #56 |
sweet thanx for the info man
05-27-2009, 06:24 PM | #57 |
I think one of our members helped DIY come up with that revision, Yukonjack was it you?? Can't remember but yeah sweet project, stop spending and get to assembling with picts. My next build will be a 496, I have three 4-bolt main 454's so I am primed and ready, can you say in excess of 600hp and 600lb/ft or TQ!!!
05-27-2009, 09:21 PM | #58 |
I can't wait till you finish so i can see a video in the mud. And yet again i haven't made it throught the bog in my truck i broke something in my front axle on the way to the bog.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
05-28-2009, 10:24 AM | #59 | |
I LOVE the 454
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
05-28-2009, 10:35 AM | #60 |
You just can't beat them for the tq and SMILES per gallon!! I have some pretty radical SBC but you have to twist them up to get them to put out the power, and in a BBC the power is effortless and down low where you want/need it!! The only other vehicle I've driven that gives the same sensation is my 07 cummins, the tq just pushes you through the seat, so go turbo'd diesel or BBC!
05-28-2009, 12:16 PM | #61 |
Oh ya, I am totaly in agreement with you!
I drive a 05LLY Duramax, commute and towing the K5! TurboDiesel is awesome on the road!
05-28-2009, 10:48 PM | #62 |
Grease Monkey
Here is a video of me mud bogging
05-28-2009, 11:12 PM | #63 |
i want a new one i have see that one.
05-28-2009, 11:24 PM | #64 |
Grease Monkey
You'll have to wait till next year. I'm taking this year off to build the motor and break it in. I also have a lot of prepping to do for the next mud bogging trip.
05-30-2009, 10:21 PM | #65 |
Grease Monkey
I know, I know. You are all ready for me to start putting it together. Well the good news is I received the last of the parts. So I am able to start assembling the engine. The bad news is that it will still be another two weeks before I will have time to start. I have a test I have to study for. Once I pass, then its on. I will have lots of pictures and current stats and info for you once I begin. Thanks you to all who are commenting and waiting patiently. Trust me the pile of parts on my garage floor is killing.
05-31-2009, 01:27 AM | #66 | |
06-29-2009, 01:01 AM | #67 |
Whats up with your truck any updates.
07-18-2009, 09:59 PM | #68 |
Grease Monkey
The only update is that I started putting the motor together this week. I'll post pictures soon. We ordered the wrong piston rings. Once I get the rings I should start making some real progress.
07-30-2009, 10:34 PM | #69 |
Grease Monkey
Finally have an update!
I found some time to work on the motor this week. I got the correct piston ring and was able to finish the short block. I am hoping to be able to fab the cross member for the tranny and the center link for the engine. I am also hoping that my buddy can finish port and polishing my heads next week. Once I have the heads, it should only take a weekend to finish this project. Enjoy, here are some pictures...
08-03-2009, 11:17 PM | #70 |
Grease Monkey
I hit a roadblock... The DIY4x cross member lowered the motor down quite a bit, causing the the headers to have serious clearance issues. I moved the engine forward 3 1/4" so the frame is narrower, but the tall valve covers clear the firewall. The exhaust ports on the heads are about an inch or two above the frame instead of 3-4". Any suggestions?
08-04-2009, 12:13 AM | #71 |
if it fits you should just leave it take the body lift off.
08-09-2009, 08:20 PM | #72 | |
Grease Monkey
Here is another shipment I received this week: New Holley Street Avenger 870cfm Carb, Holley Blue Fuel Pump w/ regulator, & Dual fuel line Flex-a-lite dual 13.5 electric fan kit Flex-a-lite Tranny Cooler with Steel braided hose w/ fittings for cooler and fuel lines
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 Last edited by Chevy1TonFun; 08-09-2009 at 08:26 PM. |
10-11-2009, 07:22 PM | #73 |
Grease Monkey
Things have come to a halt over the last month. I am hoping with SEMA almost here that my buddy will be finishing his SEMA car soon. Then I'll be able to work with him, to finish the cross members. As for the motor, the heads are waiting to be polished and then the final machining. Once the heads are done, it will only be about a few hours to finish the motor. I was able to install the transmission cooler and get the lines ran today.
10-11-2009, 10:25 PM | #74 |
so with the cross member will it a easy bolt in, or will it be hard?
10-12-2009, 10:42 AM | #75 | |
Grease Monkey
The DIY4X 67-72 crossmember is designed for a SBC. Yes, it bolts right in. So my issues are for a BBC. I talked with Kurt and he sent me another crossmember, but this one is just the pieces so that I can weld them together to fit the BBC.
