Old 05-22-2009, 06:24 PM   #1
70GMCer
70GMCer's Avatar
How To Speedo Gear Correction
Well, I finally decided to fix the speedometer on the 70 today. Ever since I converted to a 350 Turbo from a 3spd manual, the speedo has always read about 15 mph too fast. The following info and pictures are for a 2wd, 350 Turbo automatic trans.
I first had to do my research on what gears I needed for the change & what are the GM part numbers & gear colors. I went to this site http://chevelleengineer.home.comcast...eer/speedo.htm & it covers all GM trans with GM part numbers with colors.
I then went to this site to figure out what gears were needed. http://www.bgsoflex.com/speedo1.html
Keep in mine that our trucks & most others use the "1000 per mile revolution" speedometer.
The term "Driven Gear" is the gear that the speedometer cable connects to at the transmission & the term "Drive Gear" refers to the gear that fits onto the output shaft of the trans. Don't confuse the two........
You might get lucky & only have to change the "Driven Gear". No tear down of the tail shaft will be needed. In my case, I had a 22 tooth driven gear & a 10 tooth drive gear. This transmission had been installed in a mid 70's Impala before rebuilding so the rear end gears were much lower.
Turns out I couldn't go any higher than 22 teeth driven gear to obtain the desired speed correction. So, the calculation told me that with a rear end gearing of 3.73 & a tire height of 27.5", I needed a 19 tooth driven gear with a 7 tooth drive gear. You will have too know rear end gearing & tire height to do this.
The gears come in 2 different OD sizes. It seams the most common size is 1.84" OD. You have to make sure that you get a matched Drive & Driven OD size. This is noted at the 1st site I entered earlier.
1st, disconnect speedo cable from tranny. Easy enough!! Next put a drain pan under the trans tail shaft to catch tranny fluid that comes out. You will lose about 1 qt of tranny fluid, so make sure you have that to put back in.
Now remove the small bolt that holds the "Driven Gear Sleeve Housing" in the tranny. This housing just pulls out & has a rubber "O" ring on it. Be careful not to damage the "O" ring. This might come out with the driven gear attached. It not, just reach in and grab the driven gear & pull it out of the tranny.
Next, if you are going to have to replace the Drive gear on the output shaft, you are going to have to remove the drive shaft. Picture already shows drive shaft is removed.
Now, remove the (4) 9/16" bolts that hold the trans tail housing. The housing will come off easy, so remember to have the pan under to catch the fluid.
The colored speedo Drive gear is now exposed on the output shaft. Make sure that the transmission is in neutral. Grab the output shaft with your hand & rotate it to where you can see the clip as shown in picture #7. Look closely to where the screw driver is pointing. That is a clip that has to be pushed out toward the front of the tranny. You have to push on the 2 tiny prongs of the clip toward the output shaft & at the same time push the clip out all the way. Be careful as you will be needing this clip later.
The Drive gear will now come off the output shaft. All I had to do is grab, & pull. Pay attention on how the gear comes off in relation to the output shaft. There is a small hole in the shaft that has to align back up with the slot on the gear & where that clip goes back in as shown in picture #8
Picture #9 shows the new parts & old parts. I didn't replace the rear trans seal as I had just replace it before installing the trans about 200 miles back.
As shown in picture #10, you will have to tap on the new gear. Just tap around the gear lightly, & it will slide to where the old outline on the output shaft is. This is where you have to make sure that the little hole matches to the new gear. That hole is where the clip seats after reinstalling it thru the gear.
Before re-installing that gear clip, bend it back to an arch shape. When I remove it, it straightened it. If you don't bend it before putting it back in, it will be sloppy loose. You might even be able to get a new one.
Now just put everything back together. Look at picture #11 & that shows what position the Driven Gear Sleeve has to be. See the flat area on the sleeve? That's where the clamp/bolt tightens it up & holds it in place.
I found that GM dealers charge $8.00 on up each for gears. Here's a site where I bought my GM parts and the total for the 2 gears & "tail housing to case seal" was $14.59 shipped. Received them in 3 days. Here's the site. https://www.partszoneonline.com/index.php
I took my truck and checked the speedo with a GPS, and was dead on correct. This was an easy job & well worth the 1 1/2 hour spent.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-22-2009, 06:25 PM   #2
70GMCer
70GMCer's Avatar
Re: How To Speedo Gear Correction
More pics
1997 GMC Sierra Ext
1965 Mustang
Old 05-22-2009, 06:26 PM   #3
70GMCer
70GMCer's Avatar
Last pic
1997 GMC Sierra Ext
1965 Mustang
Old 05-22-2009, 06:33 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Thanks for the info and pics. Should help someone that hasn't done it yet.
68gmsee is offline   Reply With Quote
Old 05-22-2009, 06:47 PM   #5
Tetdoeuf
Invest in Gold!
Tetdoeuf's Avatar
Like me! I have to do this soon and this is going to help a lot. Thanks a lot 70GMCer!
John
Gold 1970 Chevy LWB Fleet
Tetdoeuf is offline   Reply With Quote
Old 05-23-2009, 06:51 AM   #6
70GMCer
70GMCer's Avatar
Again, wasn't all that hard to do......worth the effort......
1997 GMC Sierra Ext
1965 Mustang
Old 05-23-2009, 07:16 AM   #7
68,69 K20
They call me the Breeze...
68,69 K20's Avatar
Nice work, looks like a good thread for the FAQ index...
Mike
69 K20
"Beer is proof God loves us and wants us to be happy"....Ben Franklin
68,69 K20 is offline   Reply With Quote
Old 05-23-2009, 07:46 AM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey 70GMCer,
This is a GREAT write up....My speedo housing is leaking like a sieve.....did you do this on the ground???...or did you jack up the back of the truck to avoid losing alot of tranny fluid????
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-23-2009, 07:56 AM   #9
Legolas894
Chemist under the hood...
Legolas894's Avatar
Great posting-Will help a lot.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 05-23-2009, 10:20 AM   #10
70GMCer
70GMCer's Avatar
Originally Posted by gcburdic View Post
Hey 70GMCer,
Yep.....jacked the back of the truck up to allow most of the fluid to run toward to front. Went to about 14" off the ground in the rear. Jack stands of course, with the floor jack under the rear end housing. Still ended up losing about a quart. Glad that's all I lost......
1997 GMC Sierra Ext
1965 Mustang
Old 05-23-2009, 08:44 PM   #11
70c10
67-72 Addict!
70c10's Avatar
Nice write up Steve! Mine reads 10 over the limit. I was told I need the yellow gear that slips in at the cable.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-24-2009, 07:05 AM   #12
70GMCer
70GMCer's Avatar
Jim.....add that to the list of things we have to do to your truck....lol
1997 GMC Sierra Ext
1965 Mustang
Old 06-07-2009, 07:17 AM   #13
70GMCer
70GMCer's Avatar
Was wondering if anyone else has did this & did it work out for them.
1997 GMC Sierra Ext
1965 Mustang
Old 06-07-2009, 09:44 AM   #14
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Steve,
I have a TH400 that I pretty much used this how-to to change out my speedo housing, driven gear and gasket....(Obviously there are some differences w/ speedo housing and the clamp and gasket sizes) So needless to say I really appreciate the write up....+1 worked for me!!...Thanks
Geoff with a G
Old 11-29-2009, 10:03 PM   #15
cppursell
cppursell's Avatar
I just used this tutorial for my 350 Tranny. The instructions and pictures helped a lot! Unfortunately I accidentally broke the drive gear retainer clip... I'll have to get one of those from a local transmission shop.
Thanks!
cppursell is offline   Reply With Quote
Old 11-29-2009, 11:04 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Thanks as I am in need of doing this very soon to little daisy...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-29-2009, 11:34 PM   #17
lclippard
lclippard's Avatar
this ones going in my "favorites".
very good information!
69 burb/01 yukon chassis
65 Comet Caliente 289 4 Door Sedan
99 Millenia S (supercharged) 4 Door Sedan
02 Yamaha R6
69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136
building with a buddy:
85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194
lclippard is offline   Reply With Quote
Old 11-29-2009, 11:48 PM   #18
Byronic
The Beach Cruiser
Byronic's Avatar
Awsome. Now I won't be doing 35 in a 20 any more.
1999 Silverado DD
1966 Panel Truck
2003 Harley Road Glide
1967 Schwinn Tandem Single Speed
Byronic is offline   Reply With Quote
Old 11-29-2009, 11:58 PM   #19
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
subscribed...Have a Turbo 400 w 373's and 30 rear tire...now is reading too fast maybe 5-10 mph...this should be very helpful...this site rocks....
-Ron-
OldSkool71 is offline   Reply With Quote
Old 11-30-2009, 01:25 AM   #20
70cst
70cst's Avatar
Great info 70GMCer ... I will recommend this gets copied into the FAQ.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-09-2010, 01:14 PM   #21
mcmaster68
Great info. I need to do the same thing, went from a 3 spd on tree to a th350. Thanks.
mcmaster68 is offline   Reply With Quote
Old 03-15-2011, 11:00 PM   #22
67Slider
67Slider's Avatar
Just used your FAQ and it was a snap. Very helpful. I ordered the parts tonight. I will repost when I get them installed and let you know if the speedo is dialed in.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 03-15-2011, 11:14 PM   #23
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
this needs to go in FAQ
John
1999 Toyota Tacoma 4x4
Old 03-24-2011, 07:46 PM   #24
67Slider
67Slider's Avatar
Got it all installed. Took about 10 days for the parts to come from Partzoneonline but no worries. Cost me about 20 bucks with 2 day Fedex shipping.
I've got an orange (I think #8) drive gear(1.84 OD) and a brown(18 tooth) driven gear if anyone wants it.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 02-03-2012, 06:20 PM   #25
48richard
48richard's Avatar
Great explanation, 70GMCer, thanks.
I changed out my gears this morning to compensate for larger tires; it took about 2 hours. One thing I found out, though, that the clip holding the drive gear could not be removed with the drive gear in place. There is a tang on the clip that fits in a hole on the output shaft, so the clip cannot slide forward. I held the the two prongs on the end of the clip in with a screwdriver, and then had to tap the gear with a small hammer to slide the gear over the clip.
Anyway, without seeing from this thread how easy this is, I would probably have put it off another year. Now I have a speedo that reads 61 at true 60 from my GPS, with no needle vibration, which I am guessing came from the old gears being worn.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
