05-23-2009, 04:14 PM | #1 |
HP /TQ / CR questions
Everybody,
What do you guys think the CR of a 454 with a standard FelPro head gasket, flat top pistons, & vortec heads with a 100cc would be?? I have seen the online calculators, but I do not know the answers to all the variables. Here are the specs on the engine: 454 bored .040 over, flat top pistons, vortec heads with the stock valves (2.06 / 1.72), 280 comp cam, (specs link below), roller tip rockers, Edelbrock RPM Air Gap intake & Holley 750cfm carb. Below are the links for the cam & CR. Thanks, Chris http://www.compcams.com/Cam_Specs/Ca...?csid=388&sb=2 http://www.race-cars.net/calculators...alculator.html |
05-23-2009, 06:27 PM | #2 |
Re: HP /TQ / CR questions
If you don't know all the variables then how can we figure out the CR? Why don't you know the specs? What don't you know?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
05-23-2009, 07:43 PM | #3 |
Ok, alot of the variables automatically filled out when I hit compute. So it says that I have about a 9.6 CR with a 454 .040 (462) over & flat top pistons with 100 CC chambers on the Vortec heads & a .039 head gasket. That's good. Any idea on the HP & TQ & what RPM they would be at??
05-24-2009, 07:35 AM | #4 |
Do you know your piston depth? CR seems a bit high with 100cc heads. Although I'm not all that familiar with the BBC.
05-24-2009, 08:59 AM | #5 |
Nope, sorry, I do not know the piston depth.
05-24-2009, 09:10 AM | #6 |
I believe the piston volume would be 947.47. The rocker arm ratio is 1.7. I forgot to put that in the specs earlier.
05-24-2009, 11:24 AM | #7 |
Registered Truck Offender
OK, here is the things you MUST have to calculate the compression ratio. Leave anything to guess and you have the potential; for a total erronious answer.
Bore stroke EXACT deck clearance Gasket bore diameter Gasket thickness cc of chamber dome / valve relief volume
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 05-24-2009 at 11:25 AM. |
05-24-2009, 12:41 PM | #8 |
if you don't know the piston depth (deck clearance) then you can't come up with a CR. A .05 difference in deck clearance make it a 9:1 or 10:1 motor. That's a big difference.
05-25-2009, 11:07 AM | #9 |
oh, I did not know it made that much of a difference. I assume it's the stock height. Wouldn't it be stock if the heads have never been shaved??
05-25-2009, 02:17 PM | #10 |
If the motor has ever been apart or rebuilt, heads refurbished, a valve job...... Heads could have been milled, AND/OR the block could have been decked. That diminsion is criticle to compression ratio. The combination of deck clearance (pistons at TDC typically sit below the block deck,, unless the block has been decked) and gasket thickness makes up your 'quench'. A motor with a large quench is typically more detonation prone, and a motor with a tighter quench is typically more detonation resistant. In that you can play with compression ratios a little. If the motor is detonation prone because of a large quench, you would want to error on the conservative side of compression ratio suitable for the fuel available. Inversly if the motor is quite detonation resistant because of messaged piston domes and chambers smoothed for sharp edges, a tight quench,,,, you can bump static compression up a 1/2 a point generally and still not detonate. But it's a FINE line and something you really don't want to guess at. As is most every measurement in calculating compression.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
05-26-2009, 02:31 PM | #11 |
Thanks for the explanation Marv D. The block has been rebuilt & the heads have been pocket ported. Either way, I don't think the block has been decked or the heads milled. If they were, wouldn't that increase the CR from 9.5? A 9.5 CR is what a 454 bored .040 over (4.29 x 4.0) with flat top pistons & 100cc chamber heads & a gasket thickness of .039 calculates to. Can we base the HP & TQ calcultions off of that estimate??
05-26-2009, 06:09 PM | #12 |
Hey, it isn't in and running yet?? It was decked and the heads were shaved to true them, not zero decked, just squared. The machinist told me to figure on the 9.6-9.8 static, but the rest of the info is needed to do the actual compression ratio. I figured that engine should be close to 450-500hp and about 500lb/ft of tq. Again the machinist said he had built quite a few 462-8's along the same lines as this, but they didn't have the Vortec head, and those numbers were about right for them, so this should be at least that and then some as the Vortec heads are a way better casting then the early gm ovals.
05-26-2009, 06:37 PM | #13 |
Hey Mike,
Nope, I'm ashamed & embarrassed to say that I haven't goty it in yet. I thought I would have done it by now. I used to have money & no time, now I have the time & no money. Now I am just trying to figure out the specifics on it to waste time i guess. |
