Designated A-hole!
Truck Related Links
Everyone put your TRUCK RELATED links here.
Here's a few I like: www.metalmeet.com www.shopfloortalk.com http://www.madelectrical.com/index.shtml
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Terms and Definitions
Here is a great link I found on Google hope it works.It gives all kinds of info on automotive stuff.
http://www.mattsauto.com/index3.html Vettevet- Old but a googling fool
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 03-03-2005 at 03:07 AM. Reason: wrong link |
Designated A-hole!
For 200-4r applications http://www.geocities.com/ramairgto72...ARD/TRANS.html
For o/d tv cable set up http://www.classictrucksweb.com/tech...ble/index.html
Designated A-hole!
Engine RPM vs speed vs tire size calculators
http://www.dakota-truck.net/TIRECALC/tirecalc.html http://www.smokemup.com/auto_math/index.php
Designated A-hole!
cheaper than EAstwood
http://www.airpartsinc.com/
Designated A-hole!
Looks like a lot of good info on retoration
www.autorestorer.com
Msgt USAF Ret
excellent info site
http://images.google.com/imgres?imgu...lr%3D%26sa%3DG
Here is an excellent info site. It answers a lot of FAQs if you explore it. Vettevet
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 01-23-2006 at 05:59 PM. Reason: old link bad new link installed |
Registered Cruiser
There's great engine combo information at ryans car page
I intend to live forever. So far, so good. |
![]() Join Date: Feb 2001
More Cowbell....
Vintage radios converted from AM to AM/FM..
Antique Automobile Radio Hot Rod Signs, parts, & other cool stuff.. HotRod Hardware Want 16" or 17" ralleys? Want to widen your 15"x8" ralleys up to 15"x14"? Go here... Stockton Wheel
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 05-10-2005 at 12:44 PM. |
Car Truck Bike Nut
http://www.webrodder.com/
Check the Tech articles, lot of 67-72 truck stuff
Snow free Florida panhandle, don't miss Indiana winters Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL 68 shortfleet project 94 3500 TD dually ![]() so many cars so little time 72 K2 CST 2WD Blazer
'87 V20 4x4
http://www.hotrodscustomstuff.com/LinksVend.html
almost all inclusive vendors list has hundreds of vendors listed Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4
Car Truck Bike Nut
http://www.safestrustremover.com/ Has any one used this rust remover??
Msgt USAF Ret
Re: Links
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#15 |
RIP Mr Ron
![]() Join Date: Dec 2005
Re: Links
This one is good for casting numbers on blocks, heads, cranks, intake and exhaust manifolds. Also some carbs. WWW.chevymania.com
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
#16 |
Mad Scientist
Re: Links
Another casting # site: http://www.mortec.com/sbheads.html
Everythang relates to Beer!86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
#17 |
Global warming is a myth
I posted a Wish list of parts here.
It has a lot of links, so I though it appropriate to repost those here. Wish list for 1972 K5 Blazer Duramax Diesel - or 8.1 vortec ZF-6 manual transmission Doubler - (Off-Road Design or Klune-V) Rock Jock 60 Front 5.13's ARB 35 spline outer's (maybe Rocks front & rear) - disk brakes all-around van 14 bolt rear with disks & working parking brake - (maybe out of the same donor for the engine & transmission) Vanco hydro assist brake system hydraulic ram assist power steering - (Howe, PSC, Redneck Ram stage 2 I already have a new box) "hi-steer" crossover steering 39-42" tires with staun internal beadlocks on widened factory HD alloy wheels trim, trim, trim fenders to keep tires from ripping them up - maybe some bushwacker cut-out flares for a vintage burb. warn winch(es) 9500 ti minimum LOW COG!! York OBA with 3-gallon storage Ready-welder - Premier power box & alternator Under hood shower simple dual optima setup - marine switch, big fuse (batteries mounted along framerail in front of rear springs) Electric cooling fans with manual override for water-crossings elevated gear box & axle breather's for water crossings "water-proofed" mechanicals for water crossings functional cowl-induction hood with relocated air-intake "POR"ed (or zero-rust) frame for rust prevention Custom Flat belly-skid plate - "Massage" floorpan for drivetrain fitment63" leafs in rear (custom frame mounts with shackle-flip) about 4-5" lift - Sway-A-Way resevoir shocks center mounted traction bar to limit axle wrap, but not articulation - like Sam's off-road 52" leafs in front (custom frame mounts) about 4-5" lift - Sway-A-Way resevoir shocks Full "family-style" Cage - kinda like this, but with seat mounts & overhead stringers around the console full-length 2X6 tube rocker sliders w/ tubular step like All-pro's for toyota's, but actually welded to the 2X6 tube replacing the rockers Single exhaust tip to exit through p/r quarter in front of rear tire (above rock slider for protection) custom fuel tank with integrated steel diamond plate skid custom aux fuel tank where oem is currently with skid Custom canvas soft top (for when the camper isn't on) - Oh I wish Can-Back would make more than one of these Tubular bumpers like Off-Road design's version & something similar in back with full-sized spare capabilities, as well as 60" hi-lift, shovel autometer phantom gauges in factory bezel additional gauges along a-pillar if needed tahoe seats - (split removable 3rd seat in rear) in tan nice sound system that doesn't take up much space automated 8" flip-down touchscreen above rear view mirror for carpc interface "spotter" camera's in wheelwells protected somehow (lexan) front-facing camera & rear-view camera that automatically switches on when put in reverse vintage air a/c heat system - maybe smooth firewall Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
#18 |
Designated A-hole!
Re: Links
TBI conversion info
http://www.binderbulletin.org/forums...ad.php?t=47254
#19 |
member #16
![]() Join Date: Dec 1999
Re: Links
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#20 |
Designated A-hole!
Re: Links
Another recommended performance calculator link.
http://www.ringpinion.com/Calculators.aspx
#21 |
Designated A-hole!
Re: Links
Car craft's article on 12 bolt vs 9" rear end.
http://www.carcraft.com/techarticles...ord/index.html
| Bookmarks |
| Thread Tools | |
| Display Modes | |
