Old 05-24-2009, 11:58 PM   #1
2500HD
2500HD's Avatar
My 67 build and I have a few questions
The suspension, steering, brakes and rear end are all new a completed brfore the truck was taken apart.
I will be doing the following before it goes back to the painter. Am I forgetting anything?
1. Cab/Bed/Radiator mounts from ECE
2. Radiator (4 row) from family friend
3. Electric fan specifically for the 67-72 from Old Air Products
4. Radiator upper and lower mounts -- factory radiator was a 3 row
5. Bolt in C-notch from CPP
6. Blazer tank kit from CPP
7. Hidden hitch from CPP
8. The truck will be bagged at some point and I recall that a large hole needs to be drilled somewhere. Can anyone tell me exactly where?
I have dealt with ECE but not CPP. Is CPP gppd to deal with?
Any other input on what needed to be done before it goes back to the painter?
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 05-27-2009, 09:56 AM   #2
2500HD
2500HD's Avatar
Re: My 67 build and I have a few questions
Parts will be here in the next couple of days. Does anyone know what size and where the hole needs to be drilled for bagging at a later time?
Early Classic 4.5/6
Old 05-27-2009, 10:02 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
This might help: http://67-72chevytrucks.com/vboard/s...d.php?t=129463
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-27-2009, 10:05 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Chassis is looking good!
As for CPP, do a search and you will find many unhappy people, from parts not fitting to very poor customer service. Not that ECE is perfect but of the vendors I have dealt with over the years, they rank at the top of the list as one of the best.
As for drilling holes for the bags, it will depend on the style of bags. Typically the lower one just screws in like a stock spring. The upper mount to the frame can depend of if they are single or dual port bags. If single port, typically you enlarge the stock mounting hole for the air fitting and add holes on each side of that for the mounting flange on the bag. Spacing won't be known until you have it in hand.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-27-2009, 11:37 AM   #5
2500HD
2500HD's Avatar
Thanks guys. It looks like I will have to wait for the holes. Anything else that can be done now?
Early Classic 4.5/6
Old 05-27-2009, 12:19 PM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
WOW....that frame looks great!!!
Did you get new SS fuel and brake lines??...Also, have you made sure the frame is straight??....
My was assembled before I found out differently!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-27-2009, 12:53 PM   #7
Slick67
Sofa King Crazy!!
Slick67's Avatar
Many times a hidden hitch will not work with a rear mounted gas tank, might want to check into it! Great looking frame BTW.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-27-2009, 02:10 PM   #8
2500HD
2500HD's Avatar
No I did not change the fuel or brake lines. Frame straight??? It shoould be straight -- cross members have not been removed.
Early Classic 4.5/6
Old 05-27-2009, 02:12 PM   #9
2500HD
2500HD's Avatar
when you say many times that indicates there are combinations that will work. Any recommendations? I will search and see ehat I come up with.
Early Classic 4.5/6
Old 05-27-2009, 02:19 PM   #10
jbristo67
resident oilfield trash
jbristo67's Avatar
Let me know what you come up with I would like to run one too
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-27-2009, 02:59 PM   #11
big_al_71
big_al_71's Avatar
That frame looks good in the picts....I have dealt with CPP and had no issues...Good luck
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-27-2009, 03:07 PM   #12
jbristo67
jbristo67's Avatar
I have had pretty good luck with cpp myself
2011 Nissan Armada
Old 05-27-2009, 04:16 PM   #13
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here is the Blazer tank installed. You can see the bands are in the way of some types of hitches. The Blazer tank may affect your hitch install.
Here is another shot with an aluminum-inum tank.
Hope this helps you with deciding on the hitch and tank combo.
Old 05-27-2009, 05:08 PM   #14
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice looking frame.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-27-2009, 08:15 PM   #15
allen123
It'll buff out
allen123's Avatar
looks like alot of money! looks good
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 05-28-2009, 04:35 PM   #16
2500HD
2500HD's Avatar
Got all the parts ordered and both CPP and ECE assure me that the blazer tank can be used with the hidden hitch. I bought the hitch from ECE and the tank from CPP. There are many people on this board that have both so I will get the parts and figure it out. I am having a bit of buyers remorse right now but I guess that will pass as I get closer to getting back on the road.
Early Classic 4.5/6
Old 06-02-2009, 02:24 PM   #17
jbristo67
jbristo67's Avatar
On the hide a hitch I had a friend that didnt use his straps and J hooks and instaed rand bolts throught his hitch and the lip of the blazer tank. Looked pretty cool
2011 Nissan Armada
Old 06-07-2009, 10:11 PM   #18
2500HD
2500HD's Avatar
Made some progress. Ran into a problem with the track bar and the notch (more on that in the suspension section).
Early Classic 4.5/6
