Old 05-25-2009, 01:55 PM   #1
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Painless wiring or LMC Truck wiring...which is better?
I need a full wiring harness kit, I am not sure which to go with? my truck has a few electrical options - I did add an electric fuel pump, HEI, stronger headlights, electric cooling fans, and an air compressor. so I do need a few accessories.
any recommendations would make my life a lot easier? I don't mind spending a little extra to get a good product.
smoknbarrels is offline   Reply With Quote
Old 05-25-2009, 02:03 PM   #2
smoknbarrels
Registered Mail
Re: Painless wiring or LMC Truck wiring...which is better?
hmm, just looked up AAW.. they look pretty decent,.. or at least self proclaim... anyone have experience with them?
Old 05-25-2009, 02:11 PM   #3
chevychase
chevychase's Avatar
Found a quick link with a positive on AAW:
http://67-72chevytrucks.com/vboard/s...d.php?t=343141
I have Painless system that I haven't installed so I can't comment.
chevychase is offline   Reply With Quote
Old 05-25-2009, 02:13 PM   #4
smoknbarrels
Registered Mail
yea, I seen that too in the search, but that guy sells those kits, so it's a little biased...
Old 05-25-2009, 02:15 PM   #5
chevychase
chevychase's Avatar
Good Point!
Old 05-25-2009, 02:28 PM   #6
CG
BlahBlahBlah
There is a large thread on another car board frequented by pro car builders and AAW comes out on top with all of them. Sounds like their instruction and quality are hard to beat.
I think the harness they make for our trucks sounds a little better than the other guys offer. Musclerodz, the rep for AAW has a very good rep on this board. I dont think Josh would let him be a board vendor if the stuff he sold was crap and I dont think Musclerodz would even consider selling something that was subpar.
I was going to go with Painless until I checked the other wiring kits available. Painless is good and has a good rep, but Ill be buying one of the AAW kits for my panel next week.
Old 05-25-2009, 02:31 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Seems a lotta people go with an aftermarket harness thinking it'll be easy, or not as hard as a stock harness, but then they are always the ones asking a million questions and never getting the answers they are looking for.
If you know basic electronics, then the aftermarket ones may be better. If you are more of a novice, then you might be better doing a one for one swap with new factory stuff, and then add a couple new sub systems for your added items.
Personally, I would stick with stock stuff myself. It is so easy to add stuff that I have never seen any reason to go with aftermarket wires. Nine times out of ten, there is no reason to even replace whats there.
Old 05-25-2009, 02:50 PM   #8
CG
BlahBlahBlah
I agree, but in my case...there is nothing there =)
Old 05-25-2009, 02:53 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've never seen LMC make anything of their own. It looks a lot like Painless that they sell to me.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-25-2009, 03:08 PM   #10
smoknbarrels
Registered Mail
well I figure since I need to upgrade the alt. wiring, the headlights, dizzy, and plus my fuse block is broken off the firewall - I figure I am better off replacing the works.
If I go with the AAW set, I just hope it's easy to determine which key wires to move from the column to the dash ignition.
Old 05-25-2009, 03:14 PM   #11
Big-Blue
Big-Blue's Avatar
When the AAW set came out, they posted a nice video on MySpace I think. It may be on YouTube as well. It was several minutes long. I am not a "MySpace person" so I can't tell you how to find it.
Big-Blue is offline   Reply With Quote
Old 05-25-2009, 03:19 PM   #12
cparman
sharp as a marble
I used M&H wire fabricators on my 67 Chevelle. They were great, but AAW is just as good. Both of these companies will modify an OE harness to accept HEI, and a new style alternator. Like Longhorn man said I am a fan of an OE wiring harness. The biggest reason is that IF a problem arises in the future, you can look at a factory wiring diagram and get help. My next big project, like my Chevelle will get new wiring from one of these two companies.
cparman is offline   Reply With Quote
Old 05-25-2009, 03:19 PM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
My truck has "M & H" and it looks like OEM, fit like it,
had all of the same connectors, & same wire colors.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-25-2009, 03:26 PM   #14
Jarridlem
Jarridlem's Avatar
And usually at a higher price with shipping than the other guys!
God is good all the time! Even when the truck wont start the first time.
Jarridlem is offline   Reply With Quote
Old 05-25-2009, 04:23 PM   #15
big_al_71
big_al_71's Avatar
We rewired my complete truck and used brand new factory style harness and it took five days to complete the whole truck as I did not want to see one single wire so my assistant extended the harnesses.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-25-2009, 05:52 PM   #16
Bob B.
If you are restoring your truck factory stock, I think AAW is the way to go. High quality, the right connectors and color codes. My only advice is to be sure to check the new harness against the original or a factory wiring diagram. Once in a great while they will mix wires up in the connectors, and it is much easier to fix that problem before the harness is in the truck! Painless is probably best if you are going to add a lot of custom features like power windows or non-factory A/C. Painless is high quality too, and it is easy to add circuts.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 05-25-2009, 06:04 PM   #17
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
It sounds like you might as well go with an aftermarket style with all of the add-ons with your truck. It will give you the availibility to add relays for your headlights, fuel pump, and fan. If you were to use a reproduction you would just have to cut a bunch of it up to do your upgrades.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 05-25-2009, 06:21 PM   #18
haysonj
haysonj's Avatar
I used the painless kit and it was a piece of cake to install. the fuse panel fits in the stock location and all wires are factory color with numbers every foot or so and a book that tells what each number goes to It also separates the circuits as to engine compartment cab and tail lights. It had all the connectors I needed except the harness for the stock AC
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 05-25-2009, 07:03 PM   #19
JustLiveIt
JustLiveIt's Avatar
Hey smoknbarrels, I have my brand new Painless harness for sale in the classifieds section if you decide to go for the Painless harness. Here is the link: http://67-72chevytrucks.com/vboard/s...d.php?t=341883
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 05-25-2009, 07:10 PM   #20
stueber68
stueber68's Avatar
link doesn't work
Old 05-25-2009, 07:21 PM   #21
JustLiveIt
JustLiveIt's Avatar
Hmm... how about this link?
Old 05-25-2009, 09:15 PM   #22
heavy71chevy
heavy71chevy's Avatar
I found a 23 circut harness at speedway motors...thats the route im going....ill post link later
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 05-25-2009, 09:24 PM   #23
bubbletop1961
bubbletop1961's Avatar
Ive put in 2 ron francis systems, Both good, but their tech support was great. Almost everynight I would email a question to them, and when I got home from work the next day their was always a good answer. Dont think they ever missed one.
http://profile.myspace.com/index.cfm...ndid=186313550
Current project is for sale. 4" chop, channelled, lowered 5", http://67-72chevytrucks.com/vboard/s...d.php?t=347067
bubbletop1961 is offline   Reply With Quote
Old 05-25-2009, 10:47 PM   #24
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
www.wiringharness.com
aka M&H Fabricators.
Got mine from GMC Paul at a better price than I could have gotten from M&H (at the time). But, I have ordered directly and their harnesses are great!
Member Nr. 2770
Old 05-25-2009, 11:03 PM   #25
Skirkpat
Skirkpat's Avatar
I would suggest M&H if you have the cash, I am one who worries more about breakdowns than most, I would not put a 25.00 OEM harness in a truck I just put 20,000 in elsewhere, Just my opinion. I put M&H in my Chevelles, looks almost stock, and you can special order the options you want, pricey, but very nice. I saw probably 10 Painless sets go into my cousins cars, they did not have factory connectors as I recall, everything was spliced together? don't know if that is different on these trucks though
Skirkpat is offline   Reply With Quote
