Old 05-26-2009, 12:25 PM   #1
72stroker
Fuel tank filler/vent
I installed a poly tank from LMC. I havent had any issues until I topped off the fuel tank. I must of filled too much, because when I refueled. I couldnt get any fuel into the tank. I drained the vent line, but havent tried to refuel yet. My guess is it will work.
Is there some type of check valve that wont allow fuel to go into the vent, Do I need a vented or non vented cap?
72stroker is offline   Reply With Quote
Old 05-26-2009, 01:41 PM   #2
cdowns
cdowns's Avatar
Re: Fuel tank filler/vent
trick is to have vent line higher than tank
Old 05-26-2009, 01:45 PM   #3
72stroker
It is higher, I used a filler next with the vent line built in, and ran a hose down to the tank.
I think the problem came when I filled it into the filler neck, and it also went up the vent hose.
Old 05-26-2009, 02:14 PM   #4
caja_larga
your vent line has a ball in it for roll over. It could have stuck to the top not letting it vent.
caja_larga is offline   Reply With Quote
Old 05-26-2009, 02:30 PM   #5
72stroker
I dont have a rollover valve.
I took the hose off the vent and it was full of fuel.
Old 05-26-2009, 02:40 PM   #6
2bits
2bits's Avatar
When I installed my Blazer tank every once in a while it will do the same thing. I don't know what the reason for it is either, so while this is not much help mayber try again now that it is a different day and it might work. Worked for me It doesn't do it that often so when it happens, I just fill up some other time.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 05-26-2009, 04:32 PM   #7
UltraBlue71
UltraBlue71's Avatar
Why wouldnt the gas run out of the vent line as the fuel level in the tank dropped? Do you have a sag in the line or a U shape where the fuel was able to collect and remain?
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 05-26-2009, 04:48 PM   #8
cdowns
cdowns's Avatar
if the fuel is staying in the line theres something holding it there //i'd take the hose off and run a piece of coathanger down to see whwere the obstrucyion is
Old 05-27-2009, 07:50 AM   #9
72stroker
Ultrablue I think you are on to it. there was a little bit of a sag.
The fuel cant drain if the air has no place to go. I took the line off blew the fuel out and reinstalled. Fueled up this morning and it worked.
I was just wondering if there is a valve that would prevent it from happening again.
Old 06-02-2009, 01:00 AM   #10
UltraBlue71
Glad you figured it out, the way these trucks use gas a fella cant be spending all his time at the pumps! You have probably already tried repositioning the vent line to take the sag out other than that I dont know of a valve or vent that would help you out, a check valve maybe, depending on the design and location, but why overcomplicate it, I bet if your vent line is positioned correctly it will remained fixed. -Cory
71 LWB
