Old 05-27-2009, 09:20 AM   #1
rodman91
rodman91's Avatar
Engine mount question?
New to the forum here and this is my first post. Bought a 67 with a 350 crate motor. It used to be a 6 cyl. A friend had told me that the 6 cyl was mounted in a different spot than the v8's alittle bit more toward the front. He said the motor sits about 2 or 3 inches to far forward will, this effect anything or is this even true. Any info will help.
rodman91 is offline   Reply With Quote
Old 05-27-2009, 09:29 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Engine mount question?
it is true, there is a v6 mounting location. I have seen a V8 mounted in the v6 location, but typically they use electric fans due to space limitations. Have any pics....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-27-2009, 10:19 AM   #3
JimKshortstep4x4
Welcome to the 67-72 Chevy Truck Board from West Michigan!
The 6 cylinder mounts in the rear set of holes in the frame so that the V-8 will actually be closer to the firewall when using the 6 cylinder mounts.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-27-2009, 12:06 PM   #4
rodman91
rodman91's Avatar
My main reason for asking is that my long tubes are rubbing on the frame and the a arms if i move it back and replace drive shaft it should clear. Just wanted to see if yall had incountered something like that or not. So is the 6cyl the front or back holes in the frame? thanks
Old 05-27-2009, 12:39 PM   #5
jgreene0717
Jason
jgreene0717's Avatar
The six cylinder is mounted in the frame holes closest to fire wall and the v8 was mounted in the holes closest to the radiator core support.
jgreene0717 is offline   Reply With Quote
Old 05-27-2009, 02:28 PM   #6
michael bustamante
michael bustamante's Avatar
another reason for moving the v8 to the foward holes is that if you run an hei ignition the cap sits very close to the firewall and cracking the cap is a good possibility. even in the foward location you could run a stock cooling fan and clutch assy. but I definatly recoimmend an electric fan set up
1967custom
michael bustamante is offline   Reply With Quote
