Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-28-2009, 10:48 PM   #1
Alan72Chevy
Ignition switch wiring
I'm putting in a new ignition switch and fixing some butchered wiring to it. It starts and runs fine. Just has some wires I don't know if they should be hooked up or what they go to. Here is what I have. Truck is a '72 Cheyenne C10.
Coming down to the switch, from the harness that goes over the gauge cluster, there are 6 wires:
Red - connected to "battery" on switch
Pink - connected to switch can't remember which terminal but works so I think is right
Purple - connected to switch can't remember which terminal but works so I think is right
Brown/Yellow - connected to "accessory" on switch
Brown - thick wire - disconnected not sure where it should go
Tan - thin wire -disconnected not sure where it should go
Now on the switch there are also some wires not connected
Terminal G1 has 2 green wires going to nothing
Terminal G2 has 2 brown wires going to nothing
and there is a second "battery" terminal with a red wire going to nothing.
There is a second brown wire coming from "accessory" where the brown/yellow connects, but second wire is not connected to anything
The ones in blue above are the ones in question. Any help is greatly appreciated! Let me know if anything is not clear or if I need to provide more info.
Thanks!
Alan
1972 Cheyenne - 350, auto, PS, PB, AC - Edelbrock intake, carb, cam, headers, air breather, K & N airfilter, dual exhaust, grant steering wheel
1984 Trans Am -335 stroker
1985 Trans Am - 305 H.O.
1992 Trans Am GTA - 1 of 226
Alan72Chevy is offline   Reply With Quote
Old 05-28-2009, 11:15 PM   #2
dan42
dan42's Avatar
Re: Ignition switch wiring
There are a couple of pictures in the FAQ's of the fuse box and underdash wiring - take a look in there and see if you can find what you need. If not, just check back, and someone will get you straightened out. Good luck.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-29-2009, 08:38 AM   #3
Alan72Chevy
Yeah, I have been searching the board for about 2 days, looking at the colored wiring diagrams, and searched the faq's at:
http://67-72chevytrucks.com/vboard/s...d.php?t=262547
So far I haven’t found an answer yet. Maybe I'm just overlooking it. The wiring diagrams show the colors going to the switch, but not what they go to. Someone has spliced a new connector for the switch and didn't reconnect everything.
Old 05-29-2009, 08:45 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
http://www.geocities.com/chevroletc1070/wiringdias.html
here you go hope it helps
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-29-2009, 09:28 AM   #5
Alan72Chevy
Yes, that was the one I was missing. I think I have it figured out now.
Thanks!
