05-30-2009, 12:54 AM | #1 |
electrical gremlens..help!
ok...just noticed that after i installed my am/fm radio that my exterior lights and dash panel lights up when i apply the brakes..and when i turn the left blinker on both front and rear lights flash.. as if my flashers were on. at night when i turn on the lights the tail lights are bright...like brake lights are on all the time..now it could of been like this before i installed the radio. im not sure? i checked all brake light bulbs and front parking bulbs..all ok. i unpluged the radio..no change.i did just get it back from a transmission rebuild... anyone ever run into this problem? h e l p !
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
05-30-2009, 06:35 AM | #2 |
I am a Referee of life.
Re: electrical gremlens..help!
Check to make sure you didn't bump the brake light switch while you were wiring the new radio.Also check to see if the plug on the headlight switch is fully seated.Those are the first two things that come to mind and you may have already checked them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
05-30-2009, 07:40 AM | #3 |
sounds like you may have a bad/faulty clock spring....also make sure you have your flasher pulled out (off)...and can we get a vid of the front headlights flashing with the blinker
05-30-2009, 01:14 PM | #4 |
im sorry... headlights dont flash... just all running lights front and side.... even with headlight switch off! ????
05-30-2009, 01:17 PM | #5 |
i talked to the guy that rebuilt the trans and told him of the latest problems..he said he thought it might be the "blinker assembly in the steering column.. what do you all think? thx,dave
05-30-2009, 01:26 PM | #6 |
I would unhook the radio and see if it still does it or not then you would know if that is the problem.
05-30-2009, 02:04 PM | #7 |
yes i did that... no change.. help..
05-30-2009, 02:06 PM | #8 | |
no change...
05-30-2009, 06:45 PM | #9 |
TILT COLUMN GURU
Sounds to me like the hazard button is pushed in and either the hazard flasher is bad or not there.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
05-30-2009, 09:28 PM | #10 |
that blinker assy. is called a clock spring... or some call it a turn signal/switch assy.
05-31-2009, 01:35 AM | #11 |
TILT COLUMN GURU
Clock springs are in vehicles with air bag in steering wheel it contains the wires so they will turn with steering wheel. they were not used in GM trucks till 1995
05-31-2009, 10:24 AM | #12 | |
http://earlyclassic.com/catalog.aspx |
05-31-2009, 02:37 PM | #13 |
ok...i found it!. as i stated it started when i got it back from a trans rebuild!
well when the mechanic removed the trans cross member he torched the factory rivets and when doing so he melted the main wire harness.found it late lastnight.. now that sucks! crap...now im looking for a nos wire harness..
05-31-2009, 02:42 PM | #14 |
thanx for all your help...
05-31-2009, 04:26 PM | #15 | |
TILT COLUMN GURU
05-31-2009, 04:50 PM | #16 | |
