06-04-2009, 07:12 PM | #626 |
Re: LFD's 4dr Tahoe Build
awesome!
-68 SWB fleet.. currently 20/18" 402bb 700r4 Changing Daily AKA PROJECT ROOKIE http://67-72chevytrucks.com/vboard/s...d.php?t=314716 |
06-05-2009, 12:09 AM | #627 |
Under Construction
excellent work kevin...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
06-08-2009, 04:36 PM | #628 |
Thanks for the thread. I killed a whole day of work reading this when I should have been selling more policies. Oh well, I will have to muster some more willpower to stay away from your build threads.
06-08-2009, 06:43 PM | #629 |
06-08-2009, 09:43 PM | #630 |
Eat My Rust
06-19-2009, 08:16 PM | #631 |
Well no real progress but I did make a large purchase today From AccuAir!
Yep I have a full kit on it's way with twin comps, twin tanks, computer, valves, Ipod style control and the key remote as well. I am so looking forward to this system and getting it installed. I will run 3/8" lines and as usual I will do a full How-To install on the system with plenty of pics. I also have the front bag system almost finished in the mock up stage and as soon as I get some time I will make the final plates and up date the post. Kevin LFD Inc. |
06-20-2009, 01:27 PM | #632 |
I'm looking forward to seeing your lower bag mount finished with the shock and sway bar integrated. I hope you get time to finish it soon.
Ryan 84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
06-20-2009, 09:44 PM | #633 | |
First I need to finish XXL's truck, then once my AccuAir parts show up I plan on making brackets to mount all the parts and pieces before I get started. Kevin LFD Inc. Last edited by Rokcrln; 06-20-2009 at 09:47 PM. |
06-20-2009, 10:45 PM | #634 | |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
06-22-2009, 04:25 PM | #635 |
I've been following this build closely. I have been building a 1970 Suburban and am doing a 4th door, your build has been incredible to read through.
06-22-2009, 04:46 PM | #636 |
Seņor Member
06-22-2009, 04:53 PM | #637 |
VA72C10
06-22-2009, 07:53 PM | #638 |
06-22-2009, 09:17 PM | #639 | |
Seņor Member
BTW, three of the eagles have nearly landed. The fourth eagle is in the chute. That is all. /back to your regularly scheduled thread
06-24-2009, 08:42 PM | #640 |
[IMG][/IMG] I like it when new toys show up! It is also a great sign when the company cares enough about how everything looks when it arrives because that tells you they probably care even more about how it performs. Another great company for this is ECE (Early Classic Ent.) and if you have ever bought their products you know what I an talking about. Every thing was accounted for and it was wrapped and packaged very well as you can see. I went all out on the kit and ordered (2) 3 gal black alum tanks, two compressors, key pad controller as well as the remote key fob controller. My plan is to make mounting plates for all the sensors, air valves and computer out of 1/4" plate contoured to fit nicely for each part then drill and tap mounting holes for the items to bolt to. Then those plates will be Tig welded to my frame for a clean built in look. I am also going to be boxing in my frame and may end up running all the wires and lines through the frame with bolt in access holes in areas to get to everything. I am really looking forward to the How-To thread I plan on doing in the next few weeks as time allows. Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Also all the mounting hardware that AccuAir includes with the kit is Stainless steel! Nice attention to detail. [IMG][/IMG] They even include a nice little laminated quick reference card for the glove box! [IMG][/IMG] Last edited by Rokcrln; 06-24-2009 at 08:45 PM. |
06-24-2009, 08:51 PM | #641 |
low n' slo
nice. the 2, 3 gal tanks is enough? i want to start piecing my kit together for my 67 suburban but for reason i keep thinking i should get a 7 gal tank, but i see 5 gal for sale all the time around here.
06-24-2009, 09:08 PM | #642 |
I have 5 gallons on mine , but I would want more if I didn't have a york. Its hard to say what the magic number is.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
06-24-2009, 09:23 PM | #643 |
Their normal kit uses (1) 5 gal tank. I have had this in the past with other builds and it worked ok but I only had 1 comp. I think with (2) comps and a 6 gal it will be fine. Keep in mind I am not building this to just sit in a parking lot and play with my air suspension.
Kevin LFD Inc. |
06-24-2009, 09:29 PM | #644 |
low n' slo
true, mine is gonna be weekend only, so i probably will hardly ever drive it. oh and maybe fridays to work to show it off lol. i may go with a york though, if i cant come across a good deal a 2 compressors. where you mounting the tank and compressors?
06-24-2009, 10:30 PM | #645 | |
Don't know yet Kevin LFD Inc. |
06-24-2009, 10:45 PM | #646 |
very nice kevin, that is one sweet setup there. sure gonna hit a few jealous bones in the group i think, cause you hit mine.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
06-24-2009, 10:56 PM | #647 |
Seņor Member
07-16-2009, 01:18 PM | #648 |
what door did you use when you did the fourth door what truck did it come off
07-16-2009, 01:26 PM | #649 |
...about 4 different trucks.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-16-2009, 02:11 PM | #650 |
