Old 06-06-2009, 04:16 AM   #1
Dtech
Smile 69 C20 Longhorn
Hey guys, I just realized there was a 4x4 forum. I have a 69 C20 CST Longhorn. New 350 motor newer 400 trans, I take it out camping all the time. So I am just getting the truck operational in every aspect, Not trying to restore it due to time and money.
So the front end is next. I want to level the truck, give it a cool stance. I heard I can do this with 1 ton springs of the same year. This can will give me a rumored 2 inches in front? Is this so? And if so will the steering deal with it. Also what do it do with me lower A-arm sway bar bushings. Do I need spacers. Where can I get them. I am also ditching the drums for 8 lug discs.
Any info would reall help thanks.
Dtech is offline   Reply With Quote
Old 06-06-2009, 08:19 AM   #2
LONGHAIR
Re: 69 C20 Longhorn
Originally Posted by Dtech View Post
Hey guys, I just realized there was a 4x4 forum. I have a 69 C20 CST Longhorn. Also what do it do with me lower A-arm sway bar bushings.
What does this have to do with the 4x4 forum?
There really isn't much that you can do to lift a 3/4 ton 2 wheel drive's suspension w/o really affecting the ride quality. Taller/heavier springs will make it very stiff. You can't raise much w/o hitting the upper bump-stops, which makes for an even worse ride.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-06-2009, 11:46 PM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 69 C20 Longhorn
You could use a coil spring spacer. I know it works with the later model trucks, but I'm not completely familiar with the 67-72 2wd setups.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 06-13-2009, 08:20 AM   #4
olblue60@aol.com
member
Re: 69 C20 Longhorn
There are spring kits called "Zero Rate" They are about 1 " thick and are used on the front and rear spring perches of 4wd's for minor wheel location adjustments in height and from front to back as well. I found info. awhile back in a 4wd forum. Can I say it? The forum is "Colorado K5"
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 06-13-2009, 02:24 PM   #5
LONGHAIR
Re: 69 C20 Longhorn
This is not a 4x4..........Zero-rates will not fit the front.
Old 06-19-2009, 08:20 AM   #6
Mike_D
Re: 69 C20 Longhorn
I run a 2" longer coil and a balljoint spacer to correct for alignment. I would recommend a 1.5" spring if I could do it over. This setup allows me to run 33x12.5x17 tires with no rubbing on my 77 c20.
[IMG][/IMG]
Mike_D is offline   Reply With Quote
