Old 06-06-2009, 10:21 AM   #1
kev2809
low n' slo
kev2809's Avatar
suburban a/c options?
about 3 months ago I picked up a 67 suburban with no factory a/c. I been workin on the body so far but I was wondering what to do about the a/c. could I get it out of an older model suburban like the 80's style? or I found a 69 truck with a/c, the whole setup for 100 bucks. couls that work? just lookin at options.
kev2809 is offline   Reply With Quote
Old 06-06-2009, 02:25 PM   #2
53burb
53burb's Avatar
Re: suburban a/c options?
The '69 a/c should work. It should be like a tunnel that runs from the back to the front. The '72 is a one-year only deal. It has a setup that is real similiar to the '73-'91 style. I hve never tried, but I believe a unit from these Burbs would fit with little modifiacation if any.
53burb is offline   Reply With Quote
Old 06-06-2009, 02:48 PM   #3
kev2809
low n' slo
kev2809's Avatar
so i would be fine just getting the a/c out of the truck? and how would i be able to hook up the air running to the rear of the truck? not with rear controls, just the air from the front reaching the back. if it cant be done, no big deal. 99.9% of the time will be only me riding in it anyways.
Old 06-06-2009, 03:03 PM   #4
53burb
53burb's Avatar
Most people don't use the '69-'71 a/c because they are not usually in good condition, but if the one you might get is, then grab it if you want to. To get to the back, there are lines that run from the front to the back that supplies the freon. It then goes to the evaporator in the rear unit, then to the vents. The rear unit has a blower in it. If its just going to be for yourself, a.c from a truck or aftermarket would work.
Old 06-06-2009, 03:13 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the one he is looking at is for a truck... I'm assuming a pick up.
I would pass on that.
In all reality, I say go aftermarket. They cost quite a bit, but by the time you go through the trouble of modifying your firewall, and replacing the old stuff in the old a/c you are getting and all that jazz, you will be a few dollars shy of NEW stuff that'll probably work better.
Old 06-07-2009, 12:39 AM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
To clarify you are refering to the '72 rear air? Didn't the '72 Suburban also get dash air?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 06-07-2009, 10:22 PM   #7
kev2809
low n' slo
kev2809's Avatar
so would the 73+ would not be a good idea? what is all involved to swap it in my truck? it doesnt seem that hard but i have never looked at it..
Old 06-08-2009, 11:38 PM   #8
Longhorn Man
72 had in dash air also, yes.
