06-07-2009, 10:29 PM | #1 |
60-66 Nut
Hydroboost Mounting Plates
These hydroboost mounting plates are laser cut from 10ga mild steel and will fit all common GM hydroboost units. As you can see in the pic it has the tang in the center hole as the OEM bracket does to eliminate rotation. These plates have the 3 3/8" x 3 1/2" hole pattern that will match up with the booster adapter brackets that I sell, as well as some OEM applications.
The hydroboost unit shown in the pics below is one from a '98 Astro Van which can usually be found in salvage yards easily. Of course there are many other applications for hydroboost units, mainly diesel powered trucks and 1 ton trucks. The cost on these hydroboost mounting plates are $26.50 each plus $9.20 flatrate shipping. However if you purchase one with one of my booster adapter brackets the cost is $21.50 and no extra for shipping. This pricing is always current and up to date. To place an order, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time. Removing the nut securing the hydroboost requires a special socket. I also make those as shown farther in this thread
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-08-2021 at 09:39 PM. Reason: Shipping cost increase |
06-07-2009, 10:30 PM | #2 |
60-66 Nut
Re: Hydroboost Mounting Plates
One more pic.....
06-20-2009, 01:07 AM | #3 |
Resistance is Futile
Hey Cap'n...are you pretty familiar with swapping in these hydroboost units? I picked up a brand new one for cheap awhile ago and I am not sure what I will use it on. I will definitely pick up one of your set-ups when I get to that point.
I'm more concerned about the hoses and fittings than actually mounting the component. Ive also seen two Astro vans at the salvage yard...I should go rob the hoses, huh?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-20-2009, 06:21 PM | #4 |
http://www.purechoicemotorsports.com/index.cfm
Hey protrash. check out the link for hydroboost adapters to AN fittings. |
06-20-2009, 11:05 PM | #5 | |
60-66 Nut
06-29-2009, 03:27 PM | #6 |
Thanx toms84ss and Cap'n fab. Ive seen the kits for plumbing and thought they were rather pricey. I will continue to keep my eyes open and will utilize your services when it comes up.
I have a BBC serp set-up with the correct pwr steering pump for hydroboost. I think this is what I'll be putting in the 'burb eventually.
07-14-2009, 09:33 AM | #7 |
Formerly- 1972SuperCheyenne
Seriously considering one of the Hydroboost set-ups. Any pics of one mounted. Looks like it would clear up alot of room with the BBC in my 72. Will our lines from the prop valve tie in to the prop valve on the new valve? Have to change the length of the rod from the pedal to the booster? Basically just need to know what else is needed to make this work. Thanks man.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
07-14-2009, 10:58 PM | #8 | |
60-66 Nut
12-20-2009, 12:25 AM | #9 |
60-66 Nut
Bump
04-25-2010, 01:06 AM | #10 |
60-66 Nut
I made up a couple extra of the hydroboost nut sockets. The cost on these is $63.50 each plus a flat $9.20 for shipping. If purchased with a hydroboost adapter plate, the shipping for both would be $9.20 as well. additionally, if you purchase either of my booster adapter brackets along with the hydroboost adapter plate and the socket, it's $16.25 for shipping. Plus you get $5.00 off on the hydroboost adapter plate. This pricing is always current and up to date.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-24-2022 at 09:34 PM. Reason: Updated price |
04-25-2010, 01:50 AM | #11 |
I got mine today. The Captain does really nice work!
04-26-2010, 12:06 AM | #12 |
60-66 Nut
Thanks for the compliment Tom
05-08-2011, 01:04 AM | #14 |
Hey captian, don't know if you've had the chance to install one of these yet but I was curious, just about how to go about mounting the linkage to the pedal, I was thinking cutting the shaft then threading for a rod end?
Sam
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
05-08-2011, 07:42 AM | #15 |
1961 crewcab
will this work on a 60-62 firewall too?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-08-2011, 11:04 PM | #16 | |
60-66 Nut
Yes that is one way of doing it. Since you are a machinist, that would probably be the easiest for you. Otherwise the pushrod can be lengthened by welding on a longer rod, like maybe part of the original brake pushrod.
05-25-2011, 05:06 AM | #17 |
Collector of Projects
I would like to report that I checked a 1994 Astro/Safari hydro boost and a 2005 GMC 2500HD hydro boost and they are interchangeable. The Astro HB has a single locating keyway where the GMC 2500HD has dual keyways. The keyways are not symmetrical, but I was able to mount the factory Astro plate on the late model GMC hydro boost….
09-02-2011, 01:21 PM | #18 |
Bump so I can find again. I sent you a message cuz I want to buy a set of these brackets from you. Damn big block doesn't make enough vacuum to run brakes :-p . Anyone have pics up of installed one yet? And does anyone know if the stock hoses off of Astro van will reach and work? Got the Hydroboost, hoses, master cylinder and power steering pump for 50 bucks off of Craigslist.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
09-02-2011, 10:47 PM | #19 | |
60-66 Nut
PM sent
09-08-2011, 10:24 PM | #20 |
Looks like a nice setup Captain. I read through the posts and I am am little slow forgive me.
Will your adapter plate work with a 2002 2500hd hydroboost unit and a 73-87 firewall? Thanks |
09-08-2011, 11:38 PM | #21 |
60-66 Nut
AS far as I know, this plate will work with that hydroboost unit, but it will not bolt up to the '73-'87 firewall. Are the '73-'87 hydroboost units not readily available in your area like they are here?
09-11-2011, 05:25 PM | #22 |
So is the socket necessary to get the hydroboost out of Astro? I havent went to pick mine up yet and was wondering if I needed it to remove it or just to take OEM brackets off of it when it is out? Also does anyone know if I still have the drums on the back can I use the master cylinder from a vehicle that had discs all the way around?
09-11-2011, 11:07 PM | #23 | |
60-66 Nut
No you do not need the socket to remove the unit from the vehicle. Depending on the shape of the factory bracket, you may or may not need the socket to remove the factory mounting bracket. Some of the Astro vans' factory brackets will bolt right up to my booster brackets.
If you have a disc/drum brake system on your truck, you should run a disc/drum master cylinder with the disc/drum proportioning valve. Quote:
09-14-2011, 08:47 PM | #24 |
received mine today looks like a good quality product now one of these days when i get home i might get to install this
09-14-2011, 11:09 PM | #25 |
60-66 Nut
Thanks Bryan. I do know how it is with there just not being enough time
